Results 1 to 8 of 8
    Jun 2013
    Determine type of refrigerant in system.
    I received a call to install two new condensers. The previous were stolen from the home. On one of the coils it states that its designed for R22 or 410a. How do I determine what refrigerant was used in the past?
    Apr 2012
    winnipeg
    you have a problem..... if there is no refrigerant left who knows......
    Oct 2002
    Plano, TX
    oil smells diferent POE vs Mineral. Maybe smell line set. If TXV equip, that will tell you.
    Jan 2010
    Quote Originally Posted by linepath View Post
    On the coil marked 22/410 I would go with 410. The c/u will come with gas that is a whole lot cheaper. What about the second coil ?
    Oct 2002
    Plano, TX
    Although marked 410, it may be with mineral oil. Must be flushed because you don't know what was in it.
    Personally, I think the manufactures are alarmist with POE/mineral mix, but I am not warrantying compressors either.
    Jan 2010
    Why would anyone go with R22 these days ?
    Jun 2013
    New York
    If it has an expansion valve check that. But your best bet would be 410 after cleaning the system.
    Jun 2013
    NORTHERN
    Quote Originally Posted by drz View Post
    Nothin' like a lil' epoxy paint thinner in a pressurized can for "refrigeration flush"...
    (do not breathe nor on skin get, it)
