Results 1 to 13 of 13
    Apr 2012
    Louisiana
    SSI Media Gauge anyone use these?
    http://www.ssi-sensors.com/wp/mediagauge-digital-gauge/
    I was watching a episode of mythbusters from season 11 and saw them using one of these gauges to monitor nitrogen pressure in an ice hail gun. I looked it up and it has diaphragm that allows you to measure pressure on all kinds of stuff water, sea water, refrigerants, oil, and air. Anyone use them?
    I would not dare use my digicools to check differential water pressure on a chiller but, this could and pneumatics too. Anyway looks cools.
    Did you check price yet? The ones I've seen like that are very expensive.
    FWIW I've use my anything goes beater set of testos for water pressure before. IMO you shouldn't have anything to worry about deticating a Digi-Cool set for water pressure.
    May 2010
    Canada
    I believe the testos are actually rated for water. I would think that any of the digital gauges would be able to handle water.
    Makes me wonder about glycol......
    Item #: 3JZA7
    Found one at granger for just over 100
    1% 300 psi
    Dec 2011
    Rio de Janeiro, Brazil
    I just would like to share this doc:
    What you should know about digital test gauge accuracy… Terminal Point versus Best Fit Straight Line Accuracy.
    http://www.ashcroft.com/products/dig...d/AshDTG-1.pdf
    Quote Originally Posted by Eduardo7 View Post
    Are those all about 1 grand a pop?
    Dec 2011
    Yes, they cost almost US$1000.00
    This one cost US$258.64 and it has the same resolution (0.01 psi)
    http://www.amazon.com/ASHCROFT-DG255.../dp/B00AM1ZRKA
    http://www.ashcroft.com/products/dig.../AshDG25-1.pdf
    Looks like that one has the same spec as the low side of a Digi-Cool AK-900 and cost the same as buying it without the manifold from TTT
    Dec 2011
    No. This Ashcroft gauge has a resolution 25 times better than the AK-900
    From the AK-900 data sheet:
    "Digital readings have ¼ psi resolution on low side, 1 psi resolution on high side"
    http://digi-cool.com/wp-content/uplo...-sheet-web.pdf
    Apr 2012
    Louisiana
    Yeah, price looks reasonable on the ssi. You could build your own manifold with these things or use them for distant pressures. The old me would buy one and check it but, I'm trying to cutback on tool purchases.
    The resolution is higher but the accuracy is the same.
    I don't see the point of them displaying the high res. on the 1% version. The high dollar Ashcroft version is rated at a much better accuracy where the extra resolution might be worth reading. They are just using the same display for the cheaper version.
    Dec 2011
    itsiceman,
    First of all let me make clear that I’m not saying that the Ashcroft DG25 digital gauge is a substitute for the AK-900. No, it isn’t!
    A 0.01 psi resolution gauge may be a very good tool to do pressure test with nitrogen. The accuracy is not so important for pressure test, but the resolution is. It doesn’t matter if the system was pressurized with 149 or 150 psi. What we are looking for is if the pressure will drop. A 0.01 psi resolution gauge will give us this answer 100 times faster than a 1 psi resolution gauge will.
    Best regards,
    Eduardo
    If the reading doesn't bounce around due to the low accuracy you would be right
