Results 1 to 13 of 15
    Jun 2013
    Trane chiller cgam temp sensor replacement
    I have a fault with a cgam046 trane chiller . It faults on high suction temperature . I found that the suction temp sensor was out of calibration by 3 degrees . Is there any way of calibrating the sensor . If I need to change the sensor does the gas charge need to be removed . I could pump the system down but as it only holds 15 kg of r410 it would not take long to reclaim. It looks like the sensor sits in a pot and has no direct contact with the refrigerant .
    Also has anyone had gas leak issues with the air cooled condensors on these units . It appears that I have a gas leak on the other circuit in the middle of the coil where the pipework is supported [oil leak] . This chiller is only about 3 years old and is one of 3 . I have had contactors fail and a condenser fan motor issues on the other units as well as main circuit breakers fail . Easy to navigate through the display but reliability a bit of a concern .
    Feb 2007
    Central Coast, California
    CGAM 052F here and I find it curious that the temp sensor is off by 3 degrees. I have the same issue here on circuit 2, that being we have a high suction fault. Trane came out and discovers that with the sensor removed and compared to a Fluke hand held in ambient temperature the two disagree by 3 degrees. Not 2, not 5, but 3. The circuit when running shows a suction temperature around 80degF, we are trying to trap the data at fault time. I do not have any idea at what temperature the point faults at and Trane indicates that it varies. 3 degrees versus 80 degrees, that is on circuit 2 while at the same time circuit 1 runs with a suction temperature around 50 degrees. It would be helpful if there were a decent description of the system that could help set up a test for the fault. We have ordered a new sensor but I am not very confident.
    Jul 2013
    Pennsylvania
    I agree with you. 3 degrees difference does not explain why your suction temp is 80 degrees.
    I would check exv operation position when running and subcooling to see if it is a charge issue or exv issue?
    Jul 2013
    Pennsylvania
    To make a long story short the diagnostic trips on a degree seconds program. basically the longer the temp is out of its parameter and the further the temp is away from its parameter make it rip faster based on given conditions. Is the psi tranducer accurate?
    Jun 2013
    Ok in the end I replaced the sensor and had to get TRANE to come out as the old sensor has to be removed from the programme and then the new sensor needs to be binded to the programme. After this I have not had a problem with the system. Interestingly the new sensor is different than the old sensor. I then had the same fault occur on the other stage. Again the sensor was out by 3-4 degrees and This stage had oil staining on the air cooled coil. I removed 13 kg of gas should have been 15. Pressure testing the coil with it seperated so I wouldn't damage the chilled water heat exchanger showed that there was a crack on condenser pipe work where it goes through the steel support.
    On one of the other machines I have had a fault for loss of communications with discharge transducer. I have unplugged this to create the same fault as there are 2 sensors in the discharge. I assume this transducer will also require binding. I had to get the firmware updated the last time as well as TRANE have updated all their systems.
    I wonder if the problems on these machines are due to all the sensors and connectors being exposed to the elements as I have other chillers Carrier and Powerpax that have never had these sorts of problems.
    Nov 2011
    GA
    If i remember correctly, you suction temp has to be 5.5 degrees above your leving water temp for 5 minutes for this fault to occur.
    Jun 2015
    india
    hi,
    please give a CGAM chiller part no list
    chiller model no CGAM045E1C01B4A1AXA1C1AXXB1B2AXXXXXXXA4A
    Jun 2008
    NW Florida
    I am having the same issue with a cgam chiller less than 2 years old. It seems the sensor fails to read accurately all the time. When I would check it it was about 3 degrees off. Another tech caught it about 8 degrees off. When he restarted it was only 3 off again. Seems to be some kind of problem with these sensors. Tried to replace sensor and could not get new sensor to communicate to bind. Was told that the program needed to be updated on my laptop.
    May 2016
    philippines
    We recently experienced same issue on "suction temperature too high" alarm in circuit 2 of our 40 tonners Trane CGAM Chiller. We have noticed that during standby mode the suction temp display in ckt 2 is higher by 20 degree fahrenhiet compared to ckt 1 (which is in healthy condition). After the chiller set in operation mode & both circuit are running, the suction temp of ckt 2 increases up to 160 deg.fah. while the circuit 1 remain close to entering/leaving water temp. The discharge pressure in ckt.2 is somewhat a half value of discharge pressure in ckt.1. And by the time the EXV in ckt 2 gradually increases up to 100% opening such time the ckt.2 stopped with an alarm suction temperature too high. We suspected that the problem is within the sensor, but we are not sure if this is the cause of alarm. Is there anyone can give as light regarding with our problem. thank you
    Oct 2008
    Ventura, CA
    Ok so hers my problem with my CGAM 40 ton chiller. Hope someone can help me out.
    Unit locking out on "loss of charge." I inspect the condenser coil and sure as the world, I found a leak. Pulled the gas out. repaired the leak and recharged unit with new R-410A exactly according to the weight on the data plate.
    As luck goes, the chiller still continued to lock out on loss of charge.
    Ordered new suction line sensor and installed it. Attempted to bind new sensor but keep seeing "unable to read from selected device."
    Ok Im stuck. Chiller problems have been like one big onion with each and every layer bringing up its own problem.
    Thanks for any help you can give.
    Apr 2018
    Checking for proper flow should be verified by checking pressure curves in the IOM. Check subcooling at full load on given circuit, should be between 15-20 degrees. Access trendview in techview and plot points "superheat control compressor flow estimate" and "EXV percent flow command". Loss of charge diagnostic is generated when the ratio between those points is greater than 1.7. System is trying to maintain a ratio of 1. Also check superheat at full load, machine is trying to maintain 12 degrees and the EXV should be about 40-60% at full load.
    Apr 2018
    Make sure you're lighting up the sensor at the correct time to bind the device properly. Click bind, then light up the sensor, click okay.
    Apr 2018
    It could be the sensor. Could also be that the sensor is reading correctly and that's why your EXV is opening 100% to drop the suction temp and make 12 degrees superheat. The sensors are in wells, so no refrigerant handling to change them. If it were me I'd switch circuit 2 sensor with circuit 1. Quick way to verify if you're having a sensor problem if you see the same issue on the opposite circuit.
