Thread: BAC damper
    Sep 2003
    BAC damper
    Got a small cooling tower with a damper on top. It's got to be 10 to 15 years old. The damper is extremely had to move. The mod motor can't open it. I'm going back tomorrow to spray it down with some WD40 or something. Anyone else got an idea?
    Local 449?
    Dec 2012
    Lowell,MA
    wd40 will collect dust and bind up dampers try using graphite spray, started using it on outside air dampers and works great drys and does not collect dust
    Jul 2011
    East coast USA
    Quote Originally Posted by Mike Doran View Post
    WD to loosen and than graphite spray to lube...but i will tell you if this isn't done more often it will get worse. But i wouldn't spend a lot of money on this or even replace them. the dampers are very expensive... and not really necessary.
    mobil coat, also known as mobilrama. loosens dampers well, but stinks a bit.
    Sep 2003
    The graphite lube worked great.
    Local 449?
