    Apr 2010
    Winnipeg,Manitoba,Canada
    True cooler lights shorting
    customer has a true cooler
    TBB-4G-S
    it is a 3 door glass cooler with lights in the doors.
    The cord for the lights is at the bottom of the door. It is rubbing on the bottom hinge causing it to fray, split and spark when opened.
    Has anyone else come across this ?
    These cables were replaced 14 months ago.
    Owner will not plug these lights back in until the problem is addressed.
    thanks everyone
    Oct 2009
    Raleigh, NC
    I have seen this lots of times. Replace cordsets and route so they don't rub against anything when the doors are opened.
    Apr 2010
    I have seen it before also. Contacted manufacture. I will keep you posted as to what happens.
    Jun 2013
    N. Canada
    Quote Originally Posted by ryan79 View Post
    TBB-4G-S
    thanks everyone
    Don't be too suprised. I am getting to hate the sight of the brand " TRUE ".
    Thermostats, then evaporator leaks.
    Hospital coolers in ideal environment, 8 years and we've had enough! We're junking them and replacing the single door units with domestic fridges.
    Ah, that felt good!
