Results 1 to 4 of 4
    Tac Xenta527 NPR
    Hi,We have Inet2000 system.I want to configure Xenta 527NPR. According to Manual it can be configured via RS232 cable. Is it possible to configure it via Ethernet cable also. Thanks.
    Pacific Time Zone
    You should be able to, but I see most references using the cable.
    default IP is 192.168.255.2
    sub 255.255.255.0
    If you can't get in that way then the serial cable is the only way.
    "How it can be considered "Open" is beyond me. Calling it "voyeur-ed" would be more accurate." pka LeroyMac, SkyIsBlue, fka Freddy-B, Mongo, IndyBlue
    BIG Government = More Dependents
    "Any 'standard' would be great if it didn't get bastardised by corporate self interest." MatrixTransform
    My 5 yr old son "Dad, Siri is not very smart when there's no internet."
    Quote Originally Posted by crab master View Post
    sub 255.255.255.0
    Thanks for Default IP,I use same series IP in my PC and I can ping Xenta527 NPR. But I don,t see it online through Inet200 configuration window. What is reason and If I want to change IP of Xenta527 NPR without Ref cable is it possible.
    Pacific Time Zone
    Quote Originally Posted by coldrig View Post
    You have to set it up before you'll see it online in INET. If you don't have configuration pages available via a web browser in the 527 then you can't set it up. It's been awhile for me and INET and I mainly dealt with 527's not 527-NPR's.
    Just get a serial interface and make a cable.
    "Xenta Server serial cable guide:
    1. Connect RJ10 pin 1 to RS232 pin 2.
    2. Connect RJ10 pin 2 to RS232 pin 3.
    3. Connect RJ10 pin 4 to RS232 pin 5.
    4. Connect RS232 pin 1, 6, 4 together."
