    Chicago, IL
    A trap on the left, a trap on the right, and a trap on its side in the middle. Nice
    Jul 2000
    Northern Wisconsin
    That trap in the furnace isn't installed correctly. When that unit is horizontal the white plastic flat trap is supposed to be brought through the furnace side to hang down.
    Chicago, IL
    Quote Originally Posted by firecontrol View Post
    I know, and tried to fix it, but cold not because the furnace was too close to the floor. I ended up leaving it alone since they said it worked fine.
    Tallahassee, FL
    That return plenum/filter is really helping the efficiency out!
    Okieville
    Quote Originally Posted by SBKold View Post
    It appears the return plenum has fallen off. Oh, and putting a humidifier in the attic is a no-no at my company. One good hard freeze and its water damage city.
    Quoted by "bmathews"
    "Just call somebody out. Nobody on here can fix it from over the computer."
    Aug 2012
    NE wisconsin
    Must be in a heated space, there's no insulation on the floor. Low air flow, looks to be a few years old, I bet the heat exchanger is cracked or will be very soon.
