Results 1 to 13 of 20
    Anybody using R407 ?
    Customer had/has a leaking evap - would not replace a month ago.
    Customer had a compressor fail - would not replace evap now.
    I installed an R407 condenser and a huge LL drier
    This is the result:
    Outdoor Ambient 82
    Indoor Ambient 82
    Head press 180 lbs = bubble point 85
    Suction press 75 lbs - dew point 38
    LL temp 72
    Subcooling = 13
    Suc temp 66
    SSH = 28
    Evap air TD - 82-65 = 17
    How does it look to you?
    PHM
    Dec 2000
    Flat Rock, NC
    Haven't used it in a/c yet. Several med. temp applications have worked out fine. Those pressures appear ok. Is this txv or orifice system?
    I don't know - I can't get to the indoor coil. The system was a 28 year old Lennox 5 ton. The evap leaks but the owner has so far refused to replace it. A dry-charged R-22 unit just seemed too stupid so I used a POE unit and charged with 407C. That way he can stay with the refrigerant whenever he comes around to the idea of a new furnace and coil.
    I was surprised to see the head pressure so low with the 407. At 100 condensing the chart has 407 running about 30 lbs Higher than R22. The conditions seemed more relaxed than I expected. I want to stop by again when the house is at conditions and see how everything looks.
    PHM
    Quote Originally Posted by codgy View Post
    PHM
    Your LL temp is 10 cooler then the outdoor temp?
    Atlanta GA area
    Not picking and poking...
    If the indoor coil is old (do we know its age), Do we have a SEER rating match between the indoor coil and outdoor unit? If not... then problems may arise.
    My experience suggests higher SEER evaps work with lower SEER condensers... however higher SEER condensers do not play well with lower SEER evaps... unless the outdoor unit is smaller in tonnage. A TXV probably would help.
    Just curious... I am not familiar with a 'R407 condenser'... other than a dry unit that has POE oil in it. Is this a refer unit?
    GA-HVAC-Tech
    Jul 2010
    nebraska
    IMO that's going to bite him in the butt PHM. 407C has a huge glide and can't be topped off. It's going to cost him a small fortune every time you come out because of that leaking coil.
    Apparently so. My test gear is accurate.
    Why do you ask?
    PHM
    PHM
    The coil is original to the house which is 28 years old.
    10 SEER would be optimistic I would think.
    This condenser is OK to use for r22 and r407 - so I would think it would be a standard r22 unit - except with POE oil in the compressor.
    PHM
    Quote Originally Posted by ga-hvac-tech View Post
    PHM
    Mar 2012
    Birmingham Al
    same thing im thinking.
    Oct 2010
    Why do you ask?
    PHM
    Liquid line shouldn't be cooler than the air cooling the condenser unless there's a problem (restriction?) or your temp reading is not accurate for some reason.
    Mar 2012
    Birmingham Al
    This condenser is OK to use for r22 and r407 - so I would think it would be a standard r22 unit - except with POE oil in the compressor..
    PHM
    bought one today u are correct
    Jun 2013
    Montana
    According to my 407c pt chart your vapor pressure temp should be 48 instead of 38. Either yor sh math is wrong or mistype for sp/temp.
    3 over ambient with 13 sc. That's got to be the best refrigerant for heat exchange ever...lol
    Yeah - how can that be?
    PHM
    This is the result:
    Outdoor Ambient 82
    Indoor Ambient 82
    LL temp 72
    Subcooling = 13
    Suc temp 66
    SSH = 28
    PHM
