Results 14 to 26 of 30
    Dec 2006
    Middle Tennessee
    when the grounded motor(s) get fixed rest will run correctly!
    punch.... whack... zap....krunch... pow...oof.... OK ... enough now.... I thought the person might have been looking at a 480 volt unit and that they were talking about a single phase 277 single phase fan motor.... that said... the "no such thing" remark was wrong to the extent that single phase motors that go on those units are as far as I know are rated "440 volt" if they are single phase.... or I could be wrong.............
    Dec 2001
    Chicago, N/W burbs
    I see 460 1/ph motors all the time.
    R2B4BTU
    Feb 2007
    Dallas, Tx.
    grounded motor. the others are backfeeding their constant hot leg back to ground at the grounded motor. 1 leg to ground = 277v. and that is what the other motors are slowly spinning on.
    mike
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by coronado2412 View Post
    I thought the person might have been looking at a 480 volt unit and that they were talking about a single phase 277single phase fan motor, that said, the "no such thing" remark was wrong to the extent that single phase motors that go on those units are as far as I know are rated "440 volt" if they are single phase, or I could be wrong
    bamm, hammertime, wrong they are rated at 460 volts!
    never seen a 277 single phase condenser fan motor either!
    Houston, Texas
    check fan capacitor of each OFM
    Quote Originally Posted by addison View Post
    Hello to all I have a 30 ton RTU Lennox unit thats about 9 years old. Its been a good unit till now. I got a call for a lack of cooling from the unit,what I found was that it was tripped out on High Pressure, the whole unit!!. After I reset it.
    I found 1 fan locked up 1 not running and the other 4 running about half the speed they normally due (these are single speed fans) they are 480VAC single phase 1/3 hp motors. I could not dive into it because of a heavy rainstrom thats still dumping and its been 4 hrs and its not letting up. I would appreciated any words of wisdom on the matter(this is something that I have never seen before). Thanks Addison Ft Worth Texas
    The Gray Northwest
    No such thing as 480 volt single phase.... 480 to neutral is 277 VAC which is single phase................ slow turning motors?........ start at the capacitor... a PSC with a bad...er open cap will run only on the run winding..... a motor running in a single winding is called a split phase.... which my guess is not what you have for fan motors............
    Got a bunch of Carrier GQ30 heat pump chillers w/460 single phase condenser fan motors.
    Quote Originally Posted by hvaccop View Post
    460 between two hot legs
    i have seen some other things between 2 hot legs!
    sorry, i couldn't resist.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by jayguy View Post
    i have seen some other things between 2 hot legs! sorry, i couldn't resist.
    after a few beers get very close to the 2 hot legs and then
    Central Oregon, paradise on earth
    If you're reading off a leg that the run capacitor is on, you can get weird readings. Probably not the case, but just thought I'd say it anyway. IF it's running at the time you measure.
    I believe in latent heat.
    Apr 2003
    After The Rain stopped I found 2 blown fuses and 2 bad run caps,
    And Yes this is a 480volt 3ph unit with 6 ODFs that are 480 vac 1ph
    277 across each leg makes it a 480 volt single phase motor. End Of story>
    Nov 2003
    Boston
    Quote Originally Posted by Airmechanical View Post
    I've had to change out a 277 volt compressor on a Leibert MiniMate ceiling mount unit.
    It took the feed from the Lighting Circuit.
    Special order, too. 3 week lead time.
    Can't remember but the fans must have been 277 also.
    Edited by powerhead on more than one occasion
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by powerhead View Post
    thats why i stated i never seen, leibert is some badass equip. and thats why i did not state there is no such thing.
    i bet that was fun changing that compressor up there!
    why would ya feed from a lighting circuit?
