Results 1 to 2 of 2
    Jan 2003
    In need of an older Carrier RTU spec
    sorry, no model number but this is a typical 10-15 year old Carrier RTU. Gas heat, electric cooling 15 ton unit. I think the 20 ton unit is identical just different fan and burner configurations.
    Has the (2) LONG supply and return air duct drops with the condenser fan motors mounted in a "V" section.
    Looking for the factory spec sheet.
    If anyone has a spec sheet they can post or e-mail would be helpful.
    Sep 2006
    Lost Wages
    check this out
    It would be great if you had even the a couple of digits of the model number. If you get them try this website.
    You might just have to go through lot of literature but hope this helps.
    http://www.commercial.carrier.com/co...ETI372,00.html
