    Boston
    Refrigerant Receiver
    If you install a refrigerant reciever in a system which holds 100lbs of refrigerant, how much additional refrigerant should I expect to add?
    Mid-west
    It depends on the type of system and why you need it and what your using it for.
    Nov 2002
    NJ - WORK IN NYC AREA
    Hmm
    If you call Refrigeration Research, I belive they will tell you the receiver should hold 125% of the total charge of the system. In your case it should be sized to hold 125 LBS.
    "My hands are for sale"
