Page 1 of 4 1234 LastLast
Results 1 to 13 of 45
    Virginia
    Little coke cooler , 55 degrees
    like 3 foot tall , glass door , 134 10 oz
    customer had me take a peek while fixing a deli case
    No access ports ofcourse and i didnt have any pierce valves
    Cond had a small blanket of fur , cleaned that off
    Feeling around , the line line off compressor is kinda hot going to cond, and the compressor shell kinda hot as well , but the tube bends on the cond are ambient at top and bottom.
    drier has been replaced before judging by the aweful braze job , and its slightly cooler than ambient to touch
    all fans working fine
    I guess its time for another drier and cut out few inches of cap tube ?
    Mar 2013
    swan valley idaho
    sounds like it. did you have a "beer can cold suction line" if not then ya, pprobably restricted/low
    Salem, WI US
    Wonder how the tech charged the system who installed the filter dryer, (No Access Port)
    Betabass
    Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome.
    Virginia
    he pinched the tube off then brazed it shut. Probly worked for coke.
    Im going to add a shrader , low side only
    Suction was ambient
    Why do it half-assed?
    Install a LL drier with a built-in access valve. Use one of those little spun copper driers.
    PHM
    Quote Originally Posted by Snapperhead View Post
    Suction was ambient
    PHM
    Jul 2011
    Lehigh Valley, PA
    What you going do if cutting back the cap tube doesn't solve the problem?
    Laugh.
    Quote Originally Posted by Capz View Post
    PHM
    Virginia
    Brought the coke machine home to fix
    cut out the filter , cut it open with anticipation of seeing a busted screen with dessicant all over
    little Sob is squeeky clean inside , screen nice and shiny
    crap
    ok wheres to friggin leak
    Virginia
    Laugh.
    then scream obscenities , then whimper a little , then throw tools , then scream at the hole in the wall
    Oct 2012
    Where we mow our own grass
    Call Coke and ask them to send a tech out.
    Mar 2009
    Mid-Mo
    Call the manufacturer and insist it is under warranty. That's what the customer would do.
    Virginia
    before removal
    Oct 2012
    Does it have a brand? I may be able to get literature/cap tube size. We do work for coke. I've replaced compressors, cap tubes in stuff like that before.
