Results 1 to 13 of 13
    Jun 2013
    which layout is superior
    which layout is superior? other suggestions?
    everything will be run in attic, long term plans for finishing attic, but customer says it's okay to run venting across the middle at this point
    Feb 2011
    North East Ohio
    They both have an issue if you ask me. I would make each run originate from the main trunk line. When you tee or branch off secondary trunks you always end up with an airflow issue out of that run. It's a small enough space that anything you do will be fine as long as you size the duct correctly
    The first is the better of the 2.
    Fort Worth, TX
    Quote Originally Posted by NCHeat View Post
    Plus one. ^^^^
    The first layout not only has what is described above as a problem, it uses those airflow killing triangle boxes. If you're using flex duct for this project, you may really regret employing those triangles.
    Psychrometrics: the very foundation of HVAC. A comfort troubleshooter's best friend.
    Feb 2013
    Sonora, California, United States
    on the second design the dining room, kitchen, and part of the living room would see very little airflow.
    Fort Worth, TX
    Also, if you have good windows on the house, throw the air toward them vs. placing the registers over them. That will reduce duct runs, static pressure, and cost.
    Jun 2013
    Thanks for the feedback!
    Please let me know if my updated diagram is better.
    Thanks.
    Fort Worth, TX
    Your OP said everything will be in the attic. Depending on how the roof is pitched, I can't quite see the air handler going next to an exterior wall like it is shown on the plans.
    The duct layout appears much improved over the previous versions. How old is this house? And what type of windows does it have?
    Jun 2013
    It is all in the attic. It should fit at that spacing from the edge. The roof has a good pitch to it.
    I'm glad the layout looks better.
    1930's house. Old single-pane wood windows with newer/nice storm windows. Overall I give the windows an average rating. House is in a primary heating environment (Minnesota). Ducting is only for AC.
    Dec 2010
    Quote Originally Posted by admiralpumpkin View Post
    Thanks.
    My response to your first thread dittos NCHeat #2, Beenthere #3 and J.K #5. The problem I have with the new drawing is the AH (air handler) is getting buried. I would hate to try to service it. Also, the ductwork isn't large enough for my liking, but it's a step in the right direction.
    Jun 2013
    George2,
    Thanks for the response.
    I'm using the following as baseline cfm-to-size numbers: round metal 10" 325cfm, 12" 525cfm, flex 8" 160cfm, flex 7" 110cfm
    Could you give me a bit more information about which ductwork isn't large enough?
    Dec 2010
    I thought the 10" returns were going to be flex runs, thus my concerns for the shortage of airflow on that side of it. The supply run towards the dining room area should be 12" and add a supply to the foyer.
    Mar 2006
    Denver/Boulder
    hmmm...
    I'm trying to understand your role in all this.
    are you the Home owner?
    are you the contractor?
    if you are the contractor, why don't you know how to do this?
    if you are the Home owner, why isn't your contractor doing this?
    What lies behind us and what lies before us are small matters compared to what lies within us.
    Two pressures, four temperatures = SUCCESS!
    Boulder Heating Contractor
    For Consumers:
    For HVACR Professionals:
