    Jul 2005
    mold in master bath
    New to this site and thx for the input
    OK we have a 2400 square foot home with two return ducts...the larger one 20x25 is located in the hallway right outside the 2nd bathroom which has no mold issues. Now the master bath w/a shower stall has the mold issue. I have steam the mold clean and even scraped the old calk and replaced it with new calk and in a about 9-12 months later the mold is back. Now we have a 12x12 return air duct in the Master BR would it be a good idea to move or block the 12x12 return air duct from the bedroom into the master bath to get rid of the moisture or am I asking for more problems down the road? I see this working OK during the winter to add moisture in the air when we are heating the home w/natural gas.
    Any thoughts?
    Dec 2010
    On a Peninsula in NE NC
    You need a bath fan to run feom the time yhe shower is on and for 15/30 min after shower is off.
    If this growth is in a tiled shower it mostlikely has a header at the door wich does not allow all the steam out.
    Mildew on cauling in shower is as common as moss on a tree.
    south louisiana
    what is on the other side of the wall of the shower stall?
    is the master bath on a second floor?
    shower unit?
    it is suprising the amount of times that there is no insulation
    behind the shower units. I see it all the time in moldy
    bathroom issues.
    you don't put return air in bathrooms or kitchens.
    best of luck.
    Jul 2005
    Can you recommend one? I do all my own electrical work so that will not be a prob. Wow pretty common....pretty sad cuz the wife brings it up about once a month. A header?? What do you mean? Our shower unit has 3 sides and no top
    Jul 2005
    Quote Originally Posted by Southern Mech View Post
    Jul 2005
    Quote Originally Posted by energy_rater_La View Post
    shower unit?
    bathroom issues.
    best of luck.
    1 side exterior wall, other side clear view to garden tub, and other side is the the throne w/it's own room w/a vent insideis the master bath on a second floor? No 1 storyshower unit? Huh? Stand up shower unitit is suprising the amount of times that there is no insulation
    bathroom issues. Well I guess the only way to check is to revmove sheetrock above tile work
