Results 14 to 19 of 19
    Jan 2010
    [QUOTE=RyanHVAC;16044931] Pump nitrogen in low side, it will hold 110 psi for 2 hours, pump nitrogen in high side to 120psi and will quickly leak down to 80 psi.
    If you fill nitrogen on the low side it will go to the evaporator,compressor,out the discharge and onto condenser.
    If you fill nitrogen on the high side it will go to the condenser and STOP at the discharge. It will continue to bleed thru the cap tube and fill the evaporator. That is not a external leak but a leak thru the cap tube. Also most restrictions are where your frosting starts. I would do a compressor test.
    Jun 2013
    Atlanta, GA
    Hey guys, found the problem. Condenser is almost completely plugged up. Isolated it from the system and pumped nitrogen through it. Pushing the nitrogen in it its building pressure and just trickling out the other side. Cant clear it with the pressure so its off to the parts house tomorrow. Thanks for the help with this.
    Oct 2012
    Where we mow our own grass
    Quote Originally Posted by RyanHVAC View Post
    Good, glad to hear you got to the bottom of it. Thanks for the follow up I was curious to know if that's what it really was.
    Mar 2013
    As was I. Makes sense. Kudos for catching it. One of those rare condenser anomalies with oil and god knows what else.
    maryland, baltimore
    We do a lot of True mfg warranty work, in the past depending on the type of failure, we would change condensing unit and cap tube. By the time you flush the old unit and change the compressor there are little savings. As stated earlier when a compressor comes apart the debris is trapped in the condenser and there is no telling if all of it came out. A tech recently bought new gauges and had a hell of a time with pressures on a new unit install, core depressors were to deep in hose end.
    Jun 2013
    Atlanta, GA
    Got it up and running, what do you all think of these pressures/temps??Name:  20130626_210653.jpg
