Results 14 to 26 of 27
    Feb 2013
    Sonora, California, United States
    Quote Originally Posted by Johnnyma45 View Post
    No, both are 4-ton units.
    im talking about when you look at them not the tonnage.
    Fort Worth, TX
    Thanks for the input from all. I think what Shophound describes may be what's going on in my case; today I had it set for 78 the entire day, but late in the afternoon (~6pm) I noticed it go to 80 while the A/C ran continuously. That's telling me it can't keep up with the heat (95 deg day here in DFW today). I'm going to schedule them back out to see what they can do.
    I agree with beenthere; your system may not be properly charged. Especially if it was installed during cool or cold weather.
    But if it IS properly charged AND has correct airflow (you can't have one without the other) you then have two choices; climb all over the installer about sizing, or do something to reduce the heat gain to the upstairs portion of your house. I also live in DFW, have most of my life, and know how things get built around here. Suffice it to say, most of the time, it's built pretty damn wrong for our climate. I've spent the last five years turning my 54 year old single story house from an uncomfortable, energy guzzling pig to a watt sipping, comfortable place to live. You just can't beat a cool roof and two stage a/c...I also had 95 degrees at my place...and that's how hot my attic got. A/C cycled all day long on first stage with thermostat set at 75.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Quote Originally Posted by Shophound View Post
    Whatever are you talking about?
    What is wrong with knee walls exposed to the attic with only R-11 batts and wall studs exposed to the attic, unsealed floor truss ends allowing attic air to circulate between the floors, unsealed duct chases open to the attic, unsealed/uninsulated pull down attic stairs in the conditioned space, black composition roof shingles, 30+ non air tight light fixtures, indifferently air sealed R4 insulated ducts and air handling equipment located in the attic, and 2 or 3 powered attic ventilators?
    Jul 2012
    Quote Originally Posted by jacob-k View Post
    Yea - actually, the condenser unit is larger than the old unit. What does this mean?
    Jul 2012
    I'll ask them when they come back out tomorrow. Because the previous unit held the heat at bay, I am leaning towards something wrong with the new unit, but I'm sure there's things to fix with the house (built in 2000)
    Feb 2013
    generally better equipment, more efficient equipment will have more surface area to remove heat, but not always is the new stuff as big as the old stuff.....As stated i would start with a Superheat/subcool reading (system charge), I personally would like to see a temperature split on the coil, or what we call a delta t. the target at the coil should be somewhere around 20. it can be done at the registers and return but it would be far less accurate. but chances are if the tech finds it low he will charge it to spec (hopefully) and call it good.
    Aug 2010
    West Monroe, LA
    Oh the knee walls in my area are no diffrent! The customer/contractor will have a insulation contractor blow the walls and attic with insualtion but batt the knee walls with R-11-13 and say its done right?
    Knee walls or for that matter second floor exterior walls that are exposed to the attic are the hottest walls In the home but recive the lowest insulation for the cavity? Makes no sense what so ever! I agree with your thoughts and wish more hvac companies, general contractors, insualtion companies and customers would pay more attention to this areas.
    Fort Worth, TX
    Oh, since you put it THAT way...nothing at all!
    May 2013
    Utah
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Saint Joseph, MI
    Sounds like the system is oversized anyway. A 7f drop on a 95f day in most climates should take over 8 or 10 hours to recover But it only needs low stage to maintain 75f in those conditions.
    As mentu setbacks don't save. You must deferred all your runtime to the hottest and least efficiency operating conditions. Small setbacks make sense with time of use metering, but that's about it.
    Sent from my DROID RAZR using Tapatalk 2
    StarCat, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Jul 2012
    The tech just left. He determined the issue to be either an overcharge or a faulty TXV meter, as he read a wavering temperature split when he plugged in his device. He tried releasing some freon to bring the charge down, but it didn't fix the readings so he's called for a new TXV meter install tomorrow. Hopefully that fixes the problem, will update tomorrow after complete.
    Feb 2013
    he just released some freon? he didnt put it in anything?
