Results 1 to 12 of 12
    Apr 2012
    chicago burbs
    What caused it to go bad?
    3 phase contactor went bad, white fluffy stuff by pitted end. What caused this and how? Seriously curious.
    Sent from my SPH-D710 using Tapatalk 2
    Apr 2012
    chicago burbs
    Dec 2008
    Ontario Canada
    Wire not tight?
    Apr 2012
    chicago burbs
    Possibly, had just spades on wires. But the corrosion on just one phase?? One terminal?
    Southold, NY
    Bad connections started the problem. We see that a lot due to salt air.
    Apr 2012
    chicago burbs
    Heard that before, even southern coastal units vs midwest last 8/12 years beacuase of run time and salt. I think midwest is about 15/20ish? Been reading that low voltage can cause chattering as well. Just thought white stuff was a wierd corrosion, reaction to something only on 1 pole
    Tucson, Az
    Looks like the corrosion found on automobile battery cables.
    I've not seen that type of corrosion on a contactor.
    Where is the equipment located?
    Jim
    Tucson, Az
    Keeping the Ice Cream Frozen!
    Jul 2011
    Lehigh Valley, PA
    Loose connections get warm/hot and eventually burn up. Sometimes I have seen them get corroded too. I think it has something to do with the aluminum connectors on the contactor.
    Jun 2013
    N. Canada
    Quote Originally Posted by leaker2 View Post
    Chemical reaction (aka corrosion) is directly proportional to temperature.
    Note the contactor points... #3 badly burnt=most corrosion. #2 appears to have a start of corrosion (warmed), and removed #1 seems to have a touch.
    The airborne element that caused the reaction-that's another question.
    edit: not caused by loose wires.
    note the #3 points & bar overheating shows resistance BETWEEN fixed points. Remember your nursery rhymes? Twinkle twinkle little star,
    Power equals I squared R .
    Mar 2011
    Nw.Connecticut
    copper conductor aluminum terminal=========== loose.
    Apr 2012
    chicago burbs
    Equipment was on a rooftop with about 15 other 3_5 ton units and a couple packages. Just office buildings, but right next to I94 in chicago. Hate using spaded connectors as they are almost always loose on high volts.
