Results 14 to 26 of 26
Thread: iced up !!
    S.W. Ontario,Canada
    Quote Originally Posted by DLZ Dan View Post
    Isnt everything frozen in Canada?
    Believe it or not but we do get some hot weather......lol
    If every a...... could do this,I wouldn't have a job...
    Madison, Wisconsin
    Quote Originally Posted by dangpgt97 View Post
    Use a lift to get it out. I guess you could deice it, replace the drain pan and heaters, repair the drain line, repair the bent fan blades and possible some motors, replace whatever caused it to ice up in the first place and hope you don't find anything else wrong or bent. We could have a small coil like that replaced in 4 hours. I've replaced ones iced and damaged like that in the past. Everyone was happy at the end of the day.
    Good point
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Jun 2002
    south jersey
    Big ice cube. What caused it and what other damage did the ice cause?
    You need to put the phone down and get back to work!
    Feb 2013
    Cary NC
    was there a defrost control??? LOL
    Apr 2010
    Winnipeg,Manitoba,Canada
    found out that the freezer used to be a blast freezer using it as a regular walk in freezer now. 2 evap's in it so the other one kept up. The defrost clock faulted on the one in the picture.
    This place is not making enough money so they chose to just leave it as it is. Once it falls from the ceiling and wrecks everything else they maybe they will do something about it.
    Some people over their heads I guess.
    Jun 2006
    Probably called on a Friday at 4:00 like it just happened. I wouldn't deice that. I would replace the evap.
    That is what I was thinking. They do that to us all the time. And now it's an emergency.
    Jun 2013
    Austin, TX
    Couldn't you disable the condensing unit for that evaporator (if it has its own) or close off its liquid line valve?
    Jul 2013
    I wonder what the box temperature was when the tech arrived
    Quote Originally Posted by ryan79 View Post
    This is the worst that I have seenAttachment 396171
    Haha that's great! ... I agree that's the worst I've seen as well
    Sent from my SGH-T999L using Tapatalk 2
    Apr 2010
    Quote Originally Posted by NiHaoMike View Post
    2 evaps in the walk in freezer. It used to be a blast freezer.
    Box temp was at -10F. As the other condensing unit and evap was still operating normal.
    Jul 2009
    Kansas
    How does someone not notice THAT!
    Feb 2013
    Cary NC
    was it converted to a higher temp freezer? I use higher lightly... heh Need a cpr?
    Aug 2005
    Rutland,Vermont
    As a point of safety I would remove all power to that coil and find a way to remove it from the refrigeration system. If left the way it is some one could get a bad shock or if it breaks free they loose all the refrigerant.
