Results 1 to 4 of 4
    Jun 2011
    Carrier 19XR858750SEP Tripping on Condenser Water Temp/Flow
    Whenever the CDW in gets to 82 deg F the chiller gets very touchy, if temp changes are made its likely to trip. All the flows look good. I know CDW in should be OK at 85 to 90 but it won't do it. Any help?
    Southold, NY
    Maybe you have a flow issue!
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by TPmaker View Post
    More information is needed to diagnose. Put up a full set of readings and someone will be able to help with the diagnosis.
    Roof Rat
    Fort Worth, TX
    Clean the cooling tower sumps and condenser pump strainers if you're having flow issues. If your 19XR uses pressure transducers to measure water flow, blow out the pipes on those in case debris is clogging them. The transducers can also go bad, sometimes intermittently.
    Building Physics Rule #2:
    Building Physics Rule #3:
