Results 1 to 7 of 7
    Aug 2011
    Myrtle Beach SC
    Single pole contactor
    Is there a polarity with 240 2-phase power?
    Situation : Single pole contractor. Outdoor fan runs but compresser does not. I switched the "incoming" L1-L2 power. Compressor started.
    Am I missing something, I thought they were both 120v and had no polarity?
    Sent from my LG-P999 using Tapatalk 2
    Southeastern Pa
    Quote Originally Posted by Adamscarpentry View Post
    Yes, but not in the way that you mean it.
    The L1 and L2 conductor's identity will have no impact on the operation of the unit, barring some sort of issue with the unit, usually involving a wiring error made during a repair.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    just a note, unless you are working in an older industrial complex; you're not dealing with 2 phase power.
    Aug 2011
    Myrtle Beach SC
    yeah. I see I made a mistake. What I meant to say was single phase power.
    now that I think of it I think it was tripped out on high limit. and timing just caught it at this point whenever tge wires switched the wires, it reset.
    Southeastern Pa
    Quote Originally Posted by dandyme View Post
    It IS confusing to some, because they see two phase legs instead of three. Single Phase comes from a single phase transformer, which usually has a center tapped neutral to provide 120 volt power.
    We still have real 2-phase in parts of SW Philly.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Iraq
    can upload us a photo of the unit electric wiring diagram
    Jan 2014
    i think the compressor just tripped off. there is no polarity between the wires because they're AC
