Page 1 of 5 12345 LastLast
Results 1 to 13 of 57
    Jun 2013
    Annual "tuneups" - necessary or sales pitch
    Are these annual or bi-annual tuneups necessary for HVAC equipment or is it just a money making service for companies?
    I hear from some people that only the filter needs to be changed while everything should be left alone unless there is a change in the way the system performs.
    Other people say things should be checked.
    Jun 2005
    SW Wisconsin
    If you do a good job with filtering the return air & keep the outdoor coil clean, & know how to check the ballpark performance of your systems, then a semiannual or even an annual may not be critically important.
    Initially, after the original install every aspect of the entire system needs to be thoroughly checked for all proper design aspects & the Actual Delivered Performance of the System to the conditioned areas.
    It depends on a lot of factors, as a thorough checkup when performed properly, potentially could prevent future high dollar costs...as well as reduce monthly utility costs.
    Eugene, Oregon
    For most residential systems I don't think they are necessary. In fact, "tune-ups" can often cause more problems than they prevent. If you keep your filter clean and the system seems to be operating normally and you utility bills seem normal, then you should be okay. If you live in a harsh environment and your outdoor unit gets really dirty or you can't remember to change your filters, then a annual cleaning/inspection may be necessary.
    For commercial systems I think a maintenance program is absolutely necessary. Commercial systems are often neglected and are subject to heavy duty use and should be inspected/cleaned more often.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Sep 2003
    You call them Tuneups, They are also could be called Preventative Maintenance Visits
    For Example this Saturday will be my Annual Cottonwood Saturday.
    I visit a number of customers who live in a cottonwood zone and clean out their condenser coils
    of that dreaded cottonwood......gonna be upper 80's this weekend. Imagine those a/c's that
    will run at higher than normal temps and pressures if they didn't get the cottonwood cleaned
    out.
    Or I can't tell you the number of Contactors I replaced at at reasonable cost because there contacts were pitted and blackened that after replacement I am certain allowed better trusted voltage to the compressor
    Granted they do bring income to the Company but they also provide a service to the folks who do want them done
    Sep 2003
    Want to extend the life of your a/c system
    Not to Hijack the thread but
    Other than a properly installed a/c system (proper evac, llfd, nitrogen flow while brazing) would be to have a digital
    thermostat with a short cycle protector or time delay enabled on that thermostat.
    It keeps the thermostat off for a preset period of time to allow for equalization of pressures in the system preventing excessive wear and tear on compressors, the blowing of fuses or the tripping of circuit breakers
    and prolonging the life of an a/c system
    Jun 2013
    Thanks for the info. I live in Los Angeles. Our AC is used maybe 2 weeks a year, mostly in the late afternoon, and before bedtime to get to a comfortable temp. Once in a while it'll run a bit at night if it's really warm.
    Our heater is used more often since we have a cold house and a sensitive member of the household. This might run for a few hours every day for a couple of months.
    The reason I asked my question is not just about saving the $ or so per visit, but also because I read some other posts where people's systems were unnecessarily "adjusted" and caused further problems.
    Quote Originally Posted by pookley View Post
    I was at a lady's house last night that didn't do her annual maintenance and her whole kitchen ceiling collapsed. I guess you live and learn.
    Houston,Tx.
    So, if the line was clear and draining at the time of your PM, and this happened later on, how would a annual maintenance check helped? Your post is what we sometimes called scare tactic in this business, I would like to know the percentage of the times, someone actually prevents something drastic from happening as in your post above, compared to nothing being wrong at all.
    I like to play the law of averages. No maintenance will guarantee some probs, some maintenance will decrease the odds of having problems. Anyways I don't use scare tactics I just tell the truth and clean up the mess.
    Houston,Tx.
    For the record, I did not accuse you personally of using scare tactics, I said "Your post is what we sometimes call scare tactic in this business" "sometimes" being the key word.
    Oct 2006
    The Beach
    After two years it should be check once a year. Condensate drain-all elec. connection-check for rust-clean the condenser coils-points on contactor-amp draw on all motors. Also check all duct work for leaks and supports. Look at those take off and make sure they are still sealed. Had three last week in one attic that were laying loose in the attic. Check that charge also. And about 12 more things. Its like your car if you want it to last-Change the oil-and check all other fluids-keep it full with gasoline and check the tire pressure. You might even wash it own in a while.
    Blue Fox
    There are some small parts that should be checked every year(don't have to be checked), if they go out. They may or may not cause major damage. often they don't. but more then one compressor has died because a couple cheap parts weren't checked.
    Depends. Some companies use them as a loss leader to see what else they can con you into.
    Ours aren't cheap. Most of the techs are long experienced and most are NATE certified. They are looking to clean your unit and get it running at its peak. They aren't on commission so if they tell you a capacitor is weak, you need it. The biggest thing is keeping the outdoor coil clean. I checked out a Trane in a friend's new rental house. Talk about FILTHY. Gonna cool so much better now that it can remove some heat and since I slowed the blower down, she says the humidity level is so much lower.
    But finding techs that aren't just there to sell you something can be a problem. Maybe avoiding those under say $60? Below that most companies aren't making any money and have to sell you something to break even or make a buck.
