    water conditioning in boilers?
    I am looking for optimal water condition and also poor condition so that I can adjust appropriatley. We have test kits and gallons of chemicals for the boiler water in the mechanical room but I have not information on what I am to do with it. It is not a glycol system. thanks for any help!
    Jun 2006
    Contact the chemical supplier. They will train you if they want to keep you buying their stuff.
    Fort Worth, TX
    Boiler water sulfite level, conductivity, pH, and return line treatment are all good places to start. I'm assuming we're speaking of a steam boiler system vs. closed loop hot water. Any time water has to be made up to a boiler/steam system it will need treatment. Regular blowdowns are also essential to keep solids in check.
    On my boilers I try to keep sulfite levels above 40ppm, conductivity levels between 3,000 and 4,000 ppm. Find yourself a good chemical company as they will know your local water supply and can recommend proper treatment procedures. Ask them to get you the necessary test kits so you can take daily samples of your boiler water and know the status of the treatment. Minimizing steam and return loop leaks will also reduce amount of treatment needed to maintain a healthy steam system.
    Psychrometrics: the very foundation of HVAC. A comfort troubleshooter's best friend.
