Page 1 of 7 1234567 LastLast
Results 1 to 13 of 91
    Jun 2013
    Skinny line is chilly. No cooling. How bad?
    The outside skinny copper line is cold and gets condensation. I was told the fat line should be cold and the skinny should be hot. The outside unit starts, but I can hear it stop after a few minutes, but the fan keeps going. I called a place and they said it could be a filter somewhere or the compressor may have broken. I'd like some thoughts so I don't get taken to the cleaners. I don't see ice anywhere. Sounds like it might be expensive.
    Tallahassee, FL
    Could be worse. It sounds like it is that filter they mentioned. Id recommend not running it until its repaired.
    The next question is what clogged up the filter? That question will be tough to answer . It is a gamble on your part as to how much life the unit has. It could run for years or have another failure soon. It may be worth a shot though.
    Jun 2013
    Quote Originally Posted by SBKold View Post
    They said it could be due to installation error by the installer or I think they said valves coming loose in the compressor and clogging the filter, but they'd like to check it out first obviously.
    Jun 2013
    Ok, they are coming out next week. Any suggestions/ideas/things to look out for?
    Aug 2001
    Mechanicsville, Virginia
    Ask to see the Technicians Credentials. They are in the form of wallet cards.
    It would be nice if they hold a State issued HVAC Tradesmans license, and/or NATE certification in servicing (not only installing) your type of equipment.
    These would be in addition to the mandatory EPA certification to legally handle refrigerants.
    Oct 2006
    The Beach
    Might be time to get some new equiment. How old is the unit? And is it a heat pump? Could be a small problem. Need some more information to figure out what could be wrong.
    Blue Fox
    Jun 2013
    I don't see a little can on the skinny line which someone mentioned could be the cause. It goes all the way into the outside unit with the can.
    Jun 2013
    No heat pump. Under 5 years old. Thanks.
    Dec 2008
    Ontario Canada
    Quote Originally Posted by cano View Post
    Sometimes the filter drier (little can) can be located in tough to see places, try a google search for "refrigerant filter drier" that may give you a better indication of what you are looking for. Even if you found it, it's not something replaceable by a home owner. Did you take a temperature reading of the little line? Or just by feel
    Jun 2013
    Just searched for "refrigerant filter drier" and that's what I tried to find on my system, but don't see it anywhere. My neighbor's is right on the line as it leaves the outdoor unit.
    Houston,Tx.
    Might be "inside" the unit, look down inside of it.
    Jun 2013
    I was thinking that, but seemed like that would have been a PITA to install. I'll check when I get home. Thank you!
    Atlanta GA area
    As mentioned... do not run this unit until it is checked out
    Depending on its age... you may be in for a new system... Not trying to spend your $$$... rather prepare you for what may (or may not) happen.
    GA-HVAC-Tech
