Results 14 to 26 of 32
    Jun 2002
    south jersey
    Wonder if you could just fix some Mu Metal as a shied on the back of the case.
    I like the meters I have with the magnets built in vs a strap.
    Hey Ice, What is Mu Metal?
    You need to put the phone down and get back to work!
    Quote Originally Posted by jnsrose View Post
    Ever see Terminator 2
    NC
    I use one of those magnetic straps from a fluke. i just keep it in the ampclamp jaws. it works for me.
    Aug 2009
    Maine
    These magnets suc and the E6000 doesn't seem to want to hold. For now though it works.Name:  sc57 001.jpg
Size:  36.2 KBName:  sc57 002.jpg
Size:  42.8 KBName:  sc57 003.jpg
    Doesn't the sc57 have a swivel camp? Thinking about doing something like that for my meter. Pics when your done please.
    May 2012
    Westminster, Colorado
    Quote Originally Posted by hearthman View Post
    placing magnets right against a DMM can mess up readings. If the mfr. does not make a magnetic strap
    Magnets can certainly interfere with the meter. How much or how easily the magnets can interfere really depends on the individual meter.
    If you go with a magnetic strap, as opposed to gluing magnets to the meter, you can use the battery as a makeshift shield when you are not using the magnets. This is mainly when you are using the clamp for amp readings. You just have to make your strap is long enough and in the right place so the magnets hang down around the battery compartment. Another benefit is that the magnets will usually draw to the battery and that keeps them out of the way a little bit.
    Sep 2012
    ummm.... why not just attach a good magnet to a nylon strap with a loop at the end then pass the clamp through it........
    Or buy one from Orlandos random crap surplus store.
    http://www.skycraftsurplus.com/magneticstrapholder.aspx
    An exposed conductive magnet swinging off a meter around control panels could be dangerous.
    Sep 2012
    yeah thats why I like a removable one that you just hook the meter to when needed.
    Aug 2009
    Maine
    All good thoughts, I don't think a magnet will hurt the meter if it is placed up high toward the clamp. I know a good way to find out for sure. Yep, I am gona glue the magnets right to the case. Then we will see what we will see. I have faith in the meter. Stay tuned for the next episode .
    Sep 2012
    Quote Originally Posted by lytning View Post
    I wonder what that will do to the wireless functionality of the meter......
    Aug 2009
    Maine
    That my friend is what we are going to find out. Probably nothing for a while, but we will see.
    Quote Originally Posted by Elfshadow View Post
    Aug 2009
    Maine
    Ok magnets on meter.Name:  sc57 and MAX 005.jpg
Size:  22.7 KBName:  sc57 and MAX 006.jpg
Size:  20.4 KBName:  sc57 and MAX 007.jpg
Size:  42.9 KBName:  sc57 and MAX 008.jpg
    FWIW I took the magnetic battery door off the UEi and moved it up by the clamp and the clamp connection and the current reading bounced all over the place.
