Results 1 to 2 of 2
    Nov 2005
    Honeywell mini controller
    I still learning the excel systems so please bare with me if I fumble a Little.
    Is there an adapter for the Honeywell X1582AH mini handheld controller. all mine have the little black plug that has 14 pins . but I also see that some Excel 100's have a standard computer 9 pin serial plug for laptop connection.
    Will an adpter work?
    Thanks Mike
    SE Penna.
    Mike,
    FYI this message should be posted on the Controls forum.
    Check this piece of Honeywell literature:
    http://customer.honeywell.com/Techli...0s/74-3554.pdf
    Page 3 discusses the connection options. Basically, you need to replace your current cable with an XW582 cable, this gives you the 9-pin D-sub connector. Then you need the XW584 adapter cable to plug the XW582 into the older controllers with rectangular 14-pin connectors.
