Results 1 to 13 of 14
    need help !Carrier vs Lennox
    I have quotes to install a new central AC system in a 2,800 sqft house in NewEngland
    I norrowed it down to two companies that have been around a while and hopefully will do a good install
    1st a Lennox XC13-042-230 3.5 ton (up to 15 seer rating from web page)
    Lennox CBX32M-042-230 air handler
    2nd quote a Carrier 24ACA3 4 ton 13 seer 10 yr limited warranty on compressor
    Carrier FX4CNF048 410a coil blower (a couple grand more for install)
    not sure why it's off a 1/2 ton
    I have read Rheem/Ruud or Trane makes a better unit should I consider getting a dealer for that instead?
    any help would be great thanks
    Houston,Tx.
    Quote Originally Posted by kangaroo5 View Post
    Well I am a little bias since I sell RUUD but I would put RUUD up against anything on the market, and you will find it's hard to beat RUUD's Mod. furnace.
    Central Kentucky
    The equipment is only a component in the HVAC system that the contractor you choose will be building for you.
    Regardless of name on the equipment you need to choose the contractor that can build the best system for your needs & then be able to verify it actually is doing what he told you it would.
    Keep in mind that those SEER ratings only apply to laboratory conditions, your home isn't a lab.
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    ac only?
    That model is cooling only on the Lennox-No heatpump?
    Quote Originally Posted by mrbillpro View Post
    Since they aren't getting a furnace,guess that leaves Rude out!lol!!
    Go Carrier,that's what's we sell!
    Yes AC only
    but I will be looking into a oil fired furnace soon (Buderus)
    Mar 2002
    Richmond, Virginia
    Spend a few extra $$$ and spring for the XC15. Gets you a much nicer, quieter outdoor unit and the LSOM (Lennox Systems Operation Monitor).
    There is nothing more frightful than ignorance in action....Mark Twain
    Sep 2006
    Angier, NC
    Lennox all the way. Don't waste your time with Carrier.
    Myrtle Beach, SC
    I like Lennox better than Carrier. I just put a new Lennox XP19 in my house. But I am at least as biased as the RUUD guy.
    As to the size difference, Did either contractor do a load calculation, or did they size it based on square feet of floor area. Not doing a full load calculation would be a mistake.
    Kevin
    Sep 2001
    kalamazoo,mich
    Put a Goodman in and pocket some money. I hate Carrier and Lennox.
    Have you hugged the Earth today?
    Donny Baker rules
    Dec 2006
    Middle Tennessee
    thats brand bashing, but i agree!
    Midwest
    Hmm Pick the better contractor see if they did a load calculation
    Carrier and Lennox both make comparable equipment. Go with the contractor that makes you more comfortable. Ask to see their load calculations the one that actually ran them is more competent. Maybe the both did a load calc but I doubt it. At 2800 square feet 3.5 tons sounds low especially if you have a number of windows. There is no substitute for a load calculation.
    Mar 2006
    tex
    get the lennox and a heat pump model Xp14 or 15 its cheaper heat than oil or LPG should be good to 30 degrees the turn on oil
