Results 1 to 8 of 8
    Central Ohio
    Do I really need a 5 ton furnace?
    I live in a cinder block home shaped like an H (every wall is exterior) and the walls are only about R10 and square footage only 2250. We currently have a 5-ton York Pulse furnace (I think 90,000 Btu). The house is circa 1940 and is in desperate need of some reducting (long, long runs where there probably should be more of a trunk built out). Anyway, I'm clearly not a pro, but what are the factors to consider when considering the "tonnage" of a furnace?
    oak park,ill
    Quote Originally Posted by dave_scarpetti View Post
    You should start with a manual j load calculationand have an in depth Energy Audit done by a Professional to see ways to improve.We can't tell u whats needed without looking.Gone are the days of Rule of thumb sizing and if u have issuses with your ductwork you'll need that fixed as well to ensure proper operation.
    Fort Worth, TX
    What silkysean said. In addition, furnaces are not rated in "tonnage"; whereas the condenser of a common residential split system that would have a cooling coil at the furnace is.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Central Ohio
    Thanks. I had a pro out recently and when I asked, he said he did Manual J calcs to support his proposal. I wish I understood them. The crude scheme is going to look like this.
    And for this, he suggested a Lennox G61V. I definitely should have an energy audit done as well.
    Thanks again for the input.
    Lancaster,Ohio
    I would study up on the lennox thing before you commit! A Five ton drive (the size of blower and motor) on a furnace may be required to move all the air around the corners. A load calc will tell you how many BTU's you need for heating and how many 'tons' of cooling you need.
    IcyFlame
    Virginia
    you might consider 2 systems.
    SW FL
    Angry
    I live in a cinder block home shaped like an H ...
    ... The house is circa 1940 and is in desperate need of some reducting
    The last 10,00 pound furnace was installed circa 1908.
    Designer Dan
    Apr 2004
    Yeah, and I took it out and have the back ache to prove it.
