Results 14 to 20 of 20
    florida
    Quote Originally Posted by primmers View Post
    i always set compressor superheat, i could care less what the superheat is at the evap, i want that compressor to be protected..
    Educational forums are open.
    May 2005
    is or is not the the box temps going to be Ok when the compressor super heat is dead nuts?? and whats the most costly item in a system? and what can be ruined if the compressor super heat is right?? and why is there a sticker on the side of a compressor that calls out a temp for compressor super heat??
    just trying to learn something....
    Let's give nukes a chance.
    May 2005
    Jan 2010
    Yes, compressor superheat is crucial. With a minimum of 20* your compressor is safe from flood back. As for the evaporator it is also crucial to have the correct superheat. Freezers are typically set for 4-6 degrees were as coolers range from 8-10. If the range is not within spec. you could be over or under feeding the coil. At the compressor the superheat might be ok due to heat picked up thru the suction line run.
    May 2005
    ttt
    Apr 2010
    Winnipeg,Manitoba,Canada
    suction line frosting. Is it not insulated?
    like everyone else has said. SUPERHEAT.
    Mar 2013
    LOL no. Bro not to be a dick. But google yourself up some superheat 101. I'd give you the lay down but I'm driving.
