Results 1 to 8 of 8
Thread: HVAC SWEATING
    Jun 2013
    HVAC SWEATING
    Florida house from 2005, Trane unit. Handler is in the garage mounted to the roof. The system is sweating and producing a lot of water. Air filter is new, I have flushed the system with a house from the outside, and have added bleach water to the drip pan. It is dripping water outside. I did notice that there is a screw or two missing from the bottom of the unit. and also the overflow sensor is sucking in air, not sure if that is normal. Any ideas or is it normal with the florida high heat to sweat like that?
Size:  1.8 KBName:  DSC00388.JPG
Size:  2.0 KBName:  screw.JPG
    Jun 2013
    Anybody???
    Dec 2011
    Northwest Georgia
    Is it sweating on the outside of the entire air handler or just in a specific spot? The insulation on the cabinent is usually very thin and the high humidity in a florida garage causes them to sweat easily, I have seen it many times. Is it possible you could wrap the air handler with insulation on the outside?
    Jun 2013
    It is leaking in that one section where the duct work enters the handler, I circled the section in the first picture to show the moisture.
    Austin, Texas
    I have a problem with clicking on your pictures so I may not be seeing what I think I see. My thought is air leaks through the cabinet access panels and penetrations. You could have 58 degree supply air blowing through blower compartment and drawing in humid air from garage which will condense in blower compartment. The condensation drips from end of air handler which happens to be the low point. Try sealing up all leaks with mastic or caulk and seal access panels with tape. Just my thoughts but I see this problem regularly when our dewpoints are high.
    Jul 2011
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Further infractions may result in loss of posting privileges.
    Danae12, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Oct 2002
    Plano, TX
    Can't tell by picture. If coil is on negative side (heat pump) sucking air needs to be fixed and will stop water splashing.
