Results 1 to 9 of 9
    Apr 2013
    Portugal
    YORK YCAJ low oil pressure
    Need some help on this chiller.
    The compressors are running with 1,3-1,6 Bar, it shoul be 2 - 3 Bar. Does anyone have some information on this compressors for I start checking? This compressors are JS type E.
    Tks.
    Dec 2008
    Dixiana, AL
    I'm sorry to have to be the one to tell you this, but when you're in Rome, you need to do as the Romans do. We don't use the metric system here, and this is a US based forum. Convert to psig and psid, and repost.
    Apr 2013
    Portugal
    The compressors are running with 18,8 - 23,2 PSI, it shoul be 29 - 43,5 PSI. Does anyone have some information on this compressors for I start checking? This compressors are JS type E.
    Tks.
    FL
    If you had an email address in your profile you would have a manual right now.
    Aug 2009
    anaheim
    YCAJ Oil
    YCAJ - Apple Jack
    What Style or Model Number or Serial.
    Oil pressure: Always know the condition of your Oil Filter.
    YCAJA - Large Recips - lots of trouble with oil pressure. Assure proper cc heater operation and amps. Keep the compressors warm or you'll be cooked. Also the oil pumps love to wear in and then wear out.
    Bon Chance,
    B
    Young Bucks: Always ADD Oil.
    Experienced Techs: Adjust the Oil Level.
    Old Timers: Find the Real Problem.
    Apr 2013
    Portugal
    Quote Originally Posted by dweber101 View Post
    Just updated my profile. Tks.
    This compressor just have an oil screen/mesh on the sump. I΄ve already opened, it was ok. My next move will be open the compressor and try to search for a fault. That΄s why I asked for help here, it will be a lot easyer with a manual. Ill keep updating as soon as I find something.
    Thanks for your help.
    Somewhere in the world.
    Do all your testing to eliminate everything that obvious but to be honest these compressor are known to have internal issues if they have excessive run hours JMHO.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    FL
    Check your mail and good luck, It's probably worn out.
    Dan
    Apr 2013
    Portugal
    Thanks Dweber101. Good info you send me but this compressor is a JH63 Style. It have some differences to the one you send me.
    Before servicing the compressor I would like to have the manual.
    Tks again.
