Page 6 of 7 FirstFirst 1234567 LastLast
Results 66 to 78 of 88
  1. #66
    Mar 2013
    swan valley idaho
    So are you guys replacing hot shot and 409 with hot shot 2 now since its so much cheaper. Any issues going to HFCs or are you literally evacuating hot shot, change schraders and re charge with hot shot 2? Any txv setting changes? I see it is about half the price.
  2. #67
    Jun 2013
    Montana
    Never used hotshot2 just 416a. No adjustments needed. Works great on txv and captube.
  3. #68
    Virginia
    To control the space temperature by sensing evaporator temperature you have to inject a long on-cycle with at least a 15 to 20º differential.
    Any adjustable-differential temperature control will work but a constant cut-in control makes it simple. And if the coil has no insertion well you can just wind the long sensing tube around the coil and pull it down into the fins.
    PHM
    i would think this kind of setup would cure almost any walkin cooler with icing issues.
    I've seen the thermostats called constant cut-in , but never bought one. Like the a12-701 , or 700
    Dont they only have one adjustment ?
    On a cooler you wouldnt want the coil getting any colder than 20 correct ??
    Isnt the "cut out" the only adjustable control on it ....
  4. #69
    Jul 2011
    Lehigh Valley, PA
    The A12-700 cuts in at 37F, the A12-701 cuts in at 41F. On a R12 or r134 evap, you would be at like #2 or #3 max on the adjustment. And then some clown comes along and sets the adjuster knob to 8 or 9 and the compressor never shuts off. That works.
  5. #70
    I always thought that was the point of the constant cut-in controls - to ensure that the coil got above freezing during every off cycle so that no timed defrost control was required.
    The space temperature is controlled by the run time which is controlled by you adjusting the differential of the control. I've never never given much thought to exactly how cold the evaporator actually gets but the cut-out is adjustable from 15º to 30º. So if the highest setting cut-out the compressor at 30º and the lowest setting does it at 15º - then the middle of the range would have the compressor off at a 22.5º evaporator temperature. Which is where I always set them initially. Then I tell the customer to adjust them only one number per day in the direction they want the temperature to go.
    PHM
    Quote Originally Posted by Snapperhead View Post
    PHM
  6. #71
    Apr 2010
    San Diego, CA
    That and it's an easy way to keep the food storage units under the FDA mandated temp limit.
  7. #72
    Aug 2009
    Maine
    Guess I have been doing it wrong for the last 40 or so years. Always install defrost timer, always measure the air temp. Try not to use a pump down with an out side condenser. Gets cold in the winter, don't like to over engineer things. Life is complicated enough.
  8. #73
    Jul 2011
    Lehigh Valley, PA
    The Ranco constant cut in lowest temp set point ( dial setting #9 ) is 11F. R404 commercial temp apps run down to about 15F +/-2F using TEV's. Randell uses constant cut in's on their newer model pizza make tables & pizza retarders. I've tested and followed the temperature range with my Fluke 52. It's neat to test and follow the cycle.
    I've installed two constant cut in on older R12 units. They are working but in my case the temp controllers are hidden to prevent the user from adjusting and both set between #2 & #3.
  9. #74
    Wisconsin
    I carry the A12-701 and A12-1506. When installing, I take the first 12" of sensing cap and wind it around my pocket screwdriver creating a sensing bulb. Wedge it between the fins in the evap. and you are done. Like PHM, I set it midpoint initially. Most of the time that setting is good.
    You have to fight through some bad days to earn the best days of your life.
    You can learn something from EVERYONE.
  10. #75
    No problem with that radius ?
    I have always been reluctant to coil the sensing tube that small. To avoid it I wind the tube around the evap - pulling the loops down into the fins.
    But you wind the sensing tube around a 1/8" diameter screwdriver? I'll have to try that next time as it sure seems like it would be easier. <g>
    PHM
    Quote Originally Posted by thermofridge View Post
    PHM
  11. #76
    I know what you mean - I used to do it wrong all those years too. But one day I thought about what I was trying to accomplish and the light went on in my head: I have to use a thermostat anyway - so why not accomplish both missions with one component? Easier, simpler, and cheaper. <g>
    Plus; I think the induced off cycle timing is better for the equipment as there is no chance of short cycling. With air sensing as soon as somebody opens the door warm air rushes in and the stat brings the compressor on. If the compressor has just shut off before they open the door the compressor tries to start too quickly. With a constant cut-in stat sensing evap coil temperature that cannot happen.
    PHM
    Quote Originally Posted by lytning View Post
    PHM
  12. #77
    Jun 2013
    Montana
    They say to make it like a paper clip andstick in the fins..but I see that mostly on freezer cases. Or the the cold control for freezers already pigtailed. They do make a tool to wind it up so you don't crack the tube.
  13. #78
    Mar 2013
    swan valley idaho
    i just did one an hour ago and wrapped around an ink pen several times to make a bulb. fit perfect in evap.
    lots of great ideas on controlling temp in this thread. if you had to choose either a tstat sensing coil temp, or a pressure control only for temp control which is preferred?
    it seems like both are basically the same idea and will control defrost as well. stat maybe gets the upper hand because it wont short cycle if pressure rises from bad valves,ambient etc...
    i like both though
