Page 3 of 7 FirstFirst 1234567 LastLast
Results 27 to 39 of 88
  1. #27
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by kklobas View Post
    unfortunately no contractor . could it wire in series with lp control
    No, this thing is only able to handle 1.5 amps. You would have to add a compressor contactor or some other type of relay to get that time delay relay to work.
  2. #28
    40º and 19º I hope?
    Because 40 lbs. is 45º which is too high.
    Although 19 lbs. or degrees is probably OK.
    PHM
    ok- set control at 19 cut out, 40 cut in. I'll give that a shot overnight and see if it's enough to keep this ol betsy running a few more months. thanks for all the input.
    PHM
  3. #29
    Apr 2012
    winnipeg
    134A is a terrible refrigerant ..... i got rid of it years ago and all is well.. ....
  4. #30
    Aug 2009
    Maine
    Hey who knows how many non condensables might be in the system or how wacked the control is. The only thing we know is that he needs more spread .
    40º and 19º I hope?
    PHM
  5. #31
    What made you get rid of 134?
    PHM
    Quote Originally Posted by carmon View Post
    PHM
  6. #32
    Virginia
    its terrible with cap tube systems when the cond coil gets filthy ..... fo sho
    in cars , great idea tho , nice and chilly and lasts long time with txv
  7. #33
    But isn't that the required POE oil causing the cap tube plugging after condenser clogging - and not the actual refrigerant?
    An any cap tube replacement I do now I always add a manual reset HP control now - but I thought it was the oil coming apart; not the refrigerant.
    So which is it really?
    PHM
    Quote Originally Posted by Snapperhead View Post
    PHM
  8. #34
    Mar 2013
    swan valley idaho
    Did a true freezer today with 404a totally plugged solid dryer. Cap still ok.
    Condenser coil was very very dirty. So ya 404a plugs up also
  9. #35
    Apr 2010
    San Diego, CA
    Because its the oil, not the refrigerant causing the plugged up driers and cap tubes. It's also happening at a temperature that would have caused MO or ABO to completely break down and seize a compressor, iirc.
  10. #36
    Virginia
    PHM
    i dont know why , but dont you see alot more cap tubes clogged with 134 than 404 ?
  11. #37
    Southold, NY
    I don't see a lot of 404a cap tube systems!
  12. #38
    Jun 2013
    Montana
    http://www.google.com/url?sa=t&sourc...X8Ke61d4XoptCQ
    I would replace with 416a. It works on all oils andjalf the cost of 409
  13. #39
    I see your 416 And your 409 - and Raise you a 417!
    R-416 is: $409. for 25 lbs.
    R-414 is: $446.
    But R-417 is $290.
    Call? <g>
    PHM
    Quote Originally Posted by MontanaJon View Post
    PHM
