Results 1 to 13 of 19
Thread: Inspection???
    May 2012
    Grand Junction, CO
    Inspection???
    In a garage on the floor.
    other then the to close to the car water tank and the upside down blue exp tank the rest looks ok .
    Urbandale IA. USA
    Quote Originally Posted by pctech View Post
    Explain what is wrong with the expansion tank in that position, please.
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    May 2012
    Grand Junction, CO
    Here, a boiler can't be set on a garage floor. Must be on a stand.
    The blue exp tank is installed upside down its against code whare iam from if it filled with water the weight would snap off the nipple very easly.
    Quote Originally Posted by cehs View Post
    New York
    It's clean and shiny
    "The only way in which a human being can make some approach to knowing the whole of a subject is by hearing what can be said about it by persons of every variety of opinion and studying all modes in which it it can be looked at by every character of mind.
    No wise man ever acquired his wisdom in any mode but this."
    John Stuart Mill
    Aug 2001
    Pavilion, NY
    You could build a 18" tall wall around it in cinder blocks and meet code perhaps b-vent connector to meet clearances and check on the back if the boiler clearances as well
    Northern California
    Boiler not secure, secondary pan needed, also stand and barrier pole in order to pass in Cali. Would have recomended natural gas or lp, at least here it's cheeper to run. Not a plumber but I know that much.
    Monmouth Junction-NJ-USA
    Why would you need or want a secondary pan in a garage? Only requirded here when installed in the occupied area. By code here the flame of the appliance must be 36" above the floor when installed in a garage.
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    michigan
    Other than regional code differences......................................F UGLY!
    I am the "Wally". All others are meer imitations of the original.
    Aug 2008
    New Jersey
    Hey GJ-HVAC/R,
    I might be wrong (excuse me if I am) but I would like to question how the Temp. and pressure valve is installed. But I was always taught that the thermal element of the T&P valve should be inside of the water heater and that it is improper to install it in a stubbed out section of pipe.
    sdeery
    May 2013
    Florida
    should be on top of the water heater........ what a mess !!
    May 2012
    Upper Michigan
    Quote Originally Posted by sdeery View Post
    Hey GJ-HVAC/R,
    sdeery
    I'd say you are correct
