Results 14 to 24 of 24
    Jul 2005
    Phoenix, AZ
    What is the best way to clean a TXV screen noe that it was mentioned. Just curious.
    Sent from my DROID RAZR using Tapatalk 2
    I like to take them out and blast spray brake cleaner through them backwards. Although, unless there is no LL drier in the system, it very seldom ever needs doing.
    PHM
    Quote Originally Posted by phxhvac View Post
    PHM
    Jun 2013
    Mechanicsburg, Pa
    I've seen them where they get black gup buildup on the internal parts not allowing it to move freely. That is even with a liquid drier on. You never know what all was done to the system in the past work wise from other techs or if a burnout ever happen. holding the bulb and trying to adjust it first is something I would try first too. check liquid drier for blockage. If the txv is flared in like some cooler/freezers are, I usually just change it with complete new. when a power head fails usually it is drastic.
    Quote Originally Posted by Tommy knocker View Post
    I would actually start cheeper. Try to adjust TEV and see if it will or pull the bulb and hold it in your hand. I'd wanna know if it responds before I take the system down and open it.
    Well, based on the assumption (yeah, big assumption) that the unit was WORKING before he was called out, we must look at what has changed.
    Typically, jumping in and adjusting a TEV before determining a problem just results in more work later.
    Quote Originally Posted by hvactech1977 View Post
    I have only seen that black gunk on low temp r-22 systems.
    Jun 2013
    I took measurements across filter drier and is good. Held sensing bulb and got no change. Took apart tev and found clog screen. Cleaned and replaced. Running good super heat and subcooloing. Thanks for your input, appreciate the help to think it through. Thats the way learn and become a better tech. Thanks jpsmith and everyone that contributed!!
    Quote Originally Posted by yvnsteve View Post
    Good to hear.
    If you keep up that kind of logical thinking, and investigative process, you'll do well in this trade.
    Southeastern Pa
    NOW...get in the habit of taking and posting pictures.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2009
    Mid-Mo
    Electrical parts cleaner or PVC cleaner for me, since that's what we have on hand.
    I've actually found that squeezing and rolling the screen between my fingers, then tapping it, open end down, on a hard surface cleans 99% of the debris out of them.
    It's typically dry, flaky stuff and there is no need for cleaner.
    Jul 2011
    Nanaimo,BC, Canada!
    I typically use electrical contact cleaner as it evaporates quickly leaving behind no residue .. Some times you can blow them put with nitrogen..
