Results 1 to 13 of 26
    Can I just fill it in?
    I have a job I have to do tomorrow. A wires insulation got rubbed away and the bare wire hit the suction line causing a pin hole. Normally I like to cut it out and put in a coupling. But this is in a tight spot on a bit of a curve. It looks like it would be pretty easy to just braze over the pin hole. Its even slightly recessed due to the shorting of the wire. It looks like I could build up the solder real nice. What do you think?
    Oct 2012
    Where we mow our own grass
    I've done that before, its pretty easy especially with a small pin hole. Get the surface clean, heat the area, and fill it in with some silfos 15.
    NH
    Yep fill it in.... I've filled 3/8" holes before in condenser coils before you'll be fine.
    Oct 2011
    Chicagoland Area
    Yup
    Aug 2012
    Toronto, Canada
    Glad to see that this is an acceptable method. Just did the exact same thing to a pin hole in a liquid line 2 weeks ago. Makes me feel better about it lol
    Dec 2008
    NW Iowa
    Yes, you could cross the Grand Canyon with 15% silfos
    Mar 2012
    Birmingham Al
    Quote Originally Posted by refrepairman View Post
    true statement, im embarrassed to admit to what i have filled in with 15%. i have had 90 degree joints blow apart, never seen one fail at the braze joint. i did this exact repair in about 2 hours on friday. braze it then i like to build up a good puddle and when available i like to do a solid ring of solider around the pipe, then its holding onto it self not the copper.
    May 2013
    Oklahoma
    Quote Originally Posted by AYservicetech View Post
    Wouldn't say its acceptable. But if someone says they have never done it, they are lieing to you.
    Aug 2012
    Toronto, Canada
    Quote Originally Posted by creed View Post
    Lol true enough.. I guess acceptable wouldn't be the word to use... But none the less.. I agree that everyone has done it
    Jul 2012
    Central TX
    I don't see why filling a pin hole with silfos isn't acceptable. I have come across many Carrier splits they strapped compressor leads directly to suction line right at the bend and the vibration caused a short and blew a hole. Every one of them I fixed this way with no adverse effects. I did a better job than the factory because I put a piece of pipe insulation between so it wouldn't do it again.
    Mar 2009
    Mid-Mo
    Why not? Go for it!
    May 2013
    Oklahoma
    Quote Originally Posted by 3DFanatic View Post
    It can cause a restriction..
    Jul 2012
    Central TX
    You would have to be terrible at brazing to cause a restriction filling a pin hole
