Results 1 to 13 of 13
    Jun 2007
    Jersey
    Service guys favorite installer
    Sorry for the sideways picture. I really don't get how to rotate it on this site.
    Any fool can know. The point is to understand. Albert Einstein
    May 2011
    Western, KY
    Is that 6 fittings in 6" with zero places to cut and blocking the filter slot?...might be a record
    Nov 2011
    St. Louis
    And may we assume the back of the furnace is up against a wall?
    Jun 2007
    Jersey
    All I can say is it took some thought to pipe it in, just no consideration for the servicing. I ordered a new drain trap to exit on other side. Units only 6 months old and not our install, we did A/C after the furnace.
    Jun 2007
    Jersey
    Quote Originally Posted by hurtinhvac View Post
    It is against the wall. I should've taken a picture of the right side, nothing in the way there. They just would've needed drain line extensions to get to the drain trap.
    May 2011
    Western, KY
    Those come with the tubing to drain it out the right side so it was just a little f'you to the service guys on this one : ).
    May 2012
    Upper Michigan
    Quote Originally Posted by mason View Post
    X2
    Feb 2013
    Lamar, SC
    If it had been our installers there would be a piece of ductwork running in front of it too.
    "If you've eliminated all other possibilities whatever remains must be the truth."
    May 2011
    Western, KY
    Don't forget the high voltage, low voltage, condensate pump and the always awesome water heater 3" in front of the unit.
    Rochester, NY, USA
    ya, how many have you seen that the tube was run IN FRONT of the circuit board.....way to many
    No job to small, I can't make to big
    May 2011
    Western, KY
    Haha I knew I forgot something
    Nov 2011
    St. Louis
    OMG - that's hands down the worst one I've seen.
    Nov 2011
    michigan
    My favorite is a finished basement and they build the mechanical room with a wall right in front of furnace... have to cut a hole in wall to pull blower assembly
