Results 1 to 7 of 7
    Western New York
    Stocking Tecumseh current relays
    I was reading the thread about 3 in 1 relays, and I thought I would post on how I handle it with fractional HP Tecumseh compressors.
    A good friend at the local Tecumseh distributor sent me the following PDF that shows what relays and overloads are used on all small Tecumseh compressors. It only takes about 8 relays to cover all the pumps. I put them in a small box with a copy of the PDF, and it's great to be able to say, "your start relay is bad, but I have one in the truck".
    When I did this quite a few years ago, I think it cost about $xxx (not much) for the initial stocking.
    Experience is what you have an hour after you need it.
    Aug 2009
    Maine
    I just stock a relay hard start kit for 1/4, 1/3, and for a 1/2. Pretty much covers it.
    Jul 2000
    Cuenca EC
    The new relay & overloads from Tecumseh are a big improvement. Thanks for that pdf!
    It reminds me of years ago when Tecumseh sold a ready-made service parts kit in a box. They should consider doing that again, but have them in a neat case like the Sporlan Q-Body TEV Kit.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    Southold, NY
    Quote Originally Posted by icemeister View Post
    It took a while but i found it:
    Mar 2013
    swan valley idaho
    is that relays and start caps? cant quite read the kit number. would you mind posting- i would like to get that. do alot of restraunt coolers.
    Southold, NY
    Quote Originally Posted by kklobas View Post
    Start relays only. My wag is that kit is 25 years old.
    Apr 2002
    Dallas, TX
    Quote Originally Posted by baub View Post
    Mmmmm... I remember doing this pdf. I should update it once in a while, wouldn't you think?
    If the only tool you have is a hammer, you tend to see every problem as a nail. – Abraham Maslow
