Results 14 to 16 of 16
Thread: clogged dryer
    Mar 2009
    Mid-Mo
    Quote Originally Posted by icemeister View Post
    The only component in a system which could be the source crap is the compressor. Some compressors are crappier than others, so one might expect more crap to be generated by a crappy compressor.
    Filters are designed to catch a lot of crap. As shown in the pictures, when they've done their job they stop working because they're full of crap...so you must install a new filter to catch the remaining crap being generated by the compressor.
    The compressor will eventually stop working too...when it no longer can produce crap because it's crapped out.
    Awesome!
    new jersey
    Embraco is not that bad, no complaints from this side of the river
    Tampa Bay, FL.
    I've had driers plugged like that. I cut one open in a 134a system and all the desiccant beads were fused together like concrete. The cap tube was the same way. I believe high heat was the culprit.
    Sent from my Nexus 10 using Tapatalk 2
