Results 1 to 13 of 16
Thread: clogged dryer
    new jersey
    clogged dryer
    do any you techs out there seen a dryer clogged this much?
    was on a 4' slide top bottle cooler with a 1/3 hp embraco compressor and believe it or not is little heart was still pumping.
    i think they are great compressors, very dependable, not like Tecumseh they suck!!!!
    Isn't that just what they look like inside? Are you sure that isn't just the desiccant?
    PHM
    Quote Originally Posted by coolerman View Post
    PHM
    new jersey
    That's is the inlet of the drier, those spun drivers are clear from the inlet till 1" in, them a screen, then is the desiccant inclose in mesh bag.
    That one was full of crap from the inlet to the screen, I don't know from were that crap came from
    Jul 2000
    Guayaquil, EC
    The only component in a system which could be the source crap is the compressor. Some compressors are crappier than others, so one might expect more crap to be generated by a crappy compressor.
    Filters are designed to catch a lot of crap. As shown in the pictures, when they've done their job they stop working because they're full of crap...so you must install a new filter to catch the remaining crap being generated by the compressor.
    The compressor will eventually stop working too...when it no longer can produce crap because it's crapped out.
    Jun 2009
    DFW, TX
    Quote Originally Posted by icemeister View Post
    Looks like a Perlick. I hate those little compressors and those POS square condenser fan motors....
    maryland, baltimore
    I have seen them dirty but not like that, replace it with a Sporlan 032 capt, we cut them at the other end as that will show you what really made it to captube. Compreesor is probably failing.
    Sep 2006
    Chicago
    Had one a few years back that was clogged like that. Had to replace compressor, cap tube and drier. Started back up and it was still restricted. Outlet of the condenser was plugged with the same kind of stuff. Had to blow it out with nitro. Burned compressor oil from overheating.
    Is that when it throws a seven?
    PHM
    PHM
    new jersey
    And about using a digital thermostat that have a extra probe to strap to discharge tubing, 3 or 4" away from the compressor, that will shot off just the condensing unit when reaches 190-200 degrees, when the condenser is all clogged up
    Jun 2013
    Montana
    gotta flow nitro when brazing.... was that one 134A? plugged condenser and oil baking?
    Oct 2012
    Where we mow our own grass
    That's hilarious.
    May 2011
    Spring City, Pennsylvania, United States
    Here's a pic of a suction drier that had a 40 psi drop across it! I have a feeling that this compressor will be done pumping its crap soon.
    Jul 2005
    Southern California
    Woah 9 craps? Tell us how you really feel about that crap in the system.
    Knowledge is knowing that a tomato is a fruit. Wisdom is knowing not to put it in a fruit salad.
