Results 1 to 11 of 11
    Sep 2010
    miami,fl.
    korean ice machine
    I worked on this ice machine never heard of this brand! it has a shutoff valve in the back of the ice machine for the drain, the drain does not have an electronic valve from my under standing it must stay closed, if I open the valve it will keep dumping water and bringing in domestic water but once I valve it off it a makes ice great. but keeping it closed this means the machine cannot dump any water. honestly I feel that's how this machine works even though its not what im used to! read the instructions it doesn't makes sense how they worded thingsName:  ice 1.jpg
Size:  58.1 KBName:  ice 2.jpg
Size:  47.0 KBName:  ice 3.jpg
    Are you sure either the fill valve or the dump valve isn't stuck open?
    How can it be a manual ice machine? <g>
    PHM
    Quote Originally Posted by anthonyac1 View Post
    PHM
    Oct 2011
    Chicagoland Area
    An ice machine doesn't have to dump water for ice production. It dumps water to remove minerals from the trough. Maybe the manual valve is for cleaning purposes. Got to love the attempt at translation.
    Quote Originally Posted by 2sac View Post
    I was just reading about Kentucky Fried Chicken the other day,Finger Licking Good turned into ,Eat your fingers off ,when they opened in China!
    Jan 2005
    where it's nice and warm
    There should be a kid behind operating the valve.
    Dec 2010
    Woodbridge Twp, NJ
    That's how it works, it keeps the water level in the machine and just keeps reusing it. To flush the minerals, you have to open that manual drain valve.
    Every customer you take for granted today will be someone else's tomorrow.
    Sep 2010
    miami,fl.
    I agree with you, it does not need to dump water to produce ice. But It seemed strange to run without dumping water to remove sediments, even a cooling tower dumps water every so often!!!! It had a manual dump valve if I opened it the machine will continue to dump water and continue to bleed makeup water into the trough. I left it closed it produce good ice
    Mount Airy, MD
    Quote Originally Posted by holdi View Post
    I will take care about this. Do not you worry.
    Well this should be fun
    Oct 2011
    Chicagoland Area
    Jun 2002
    Dacula, GA
    You can install a solenoid timer valve downstream of the shutoff valve. You will be able to vary how often it dumps and the duration of the opening of the valve. This of course will cost a little. Should have had it on there from get go.
    Sen. Barry Goldwater
    That is such a good idea that I wish I had thought of it. However; I will now quietly steal it from you for my own future glorification. <g>
    Thanks.
    PHM
    PHM
