Page 2 of 5 FirstFirst 12345 LastLast
Results 14 to 26 of 54
    May 2013
    Dkirkey28
    Quote Originally Posted by Brent Ridley View Post
    Yes. I need the outdoor condenser model number to give you exact A/C output numbers.
    Tip: If you post in the correct section with an appropriate title that will facilitate more valid responses.
    thanks
    HAVE A CARRIER INFINITY SYSTEM…24ANB748 WITH A CNPU481 n coil – 2 STAGE AIR CONDITIONER
    It is in the correct section now.
    May 2009
    Cumming, GA
    Dkirkey28
    Cooling.
    First Stage output: 39,000 Btu
    Second stage output: 47,500 Btu
    May 2013
    THANKS BRENT RIDLEY
    I DO APPRECIATIVE YOU AND THE ANSWER.
    WHAT I DON'T UNDERSTAND IS WHY CARRIER DOESN WANT TO PRINT THIS INFORMATION.
    THANK YOU VERY MUCH
    May 2013
    MR. BRENT RIDLEY
    DO YOU HAVE ANY THOUGHTS ABOUT MY QUESTION WITH THE THERMOSTAT SYSTXCCUID01-V- IT HAS NO BATTERY
    IF WE LOSE AC POWER TO THE HOSE FOR 7 DAYS, WHEN THE AC COMES BACK ON --WHAT WILL THE SETTINGS BE.
    HAVE SEEN STATEMENTS ABOUT MFG FALL SETTINGS. ANY IDEA WHAT THOSE SETTINGS WOULD BE. IF THE OUTSIDE TEMPATURE IS
    WAY BELOW 0 WILL MY PIPES FREEZE. I KNOW THE CLOCK WILL NOT BE CORRECT.
    DKIRKEY28
    May 2013
    ONE HEED TO FIX A PROBLEM ONE -ONE ALSO NEEDS TO DOCUMENT THE ANSWER FOR ALL TO SEE.
    WHERE IS IT DOCUMENTED ?
    May 2013
    MR. BRENT RIDLEY.
    READING YOUR TIP: If you post in the correct section with an appropriate title that will facilitate more valid responses.
    IAM NEW TO THIS FORUM-AFTER 340 VIEWS AND 18 RESPONSE-- WHAT POST AND WHAT IS THE CORRECT SECTION'S
    FOR MY QUESTIONS ?-- RE AFTER 7 DAYS NO POWER--
    ALSO -- WHAT DO YOU SUGGEST FOR AN APPROPRIATE TITLE ?-- I AM A RETIRED ENGINEER.
    THANK YOU
    DKIRKEY28
    Quote Originally Posted by Dkirkey28 View Post
    MR. BRENT RIDLEY
    DKIRKEY28
    If the outside temp is below 0°F and you lose power for 7 days, yes your pipes will freeze.
    Your thread now has a proper title. And it was already in the proper forum.
    May 2013
    How many times must one fix something before it is fixed? ONE NEED TO FIX A PROBLEM ONE TIME-ONE ALSO NEEDS TO DOCUMENT THE ANSWER FOR ALL TO SEE.
    You bought a specialized control. that only works on certain Carrier and Bryant equipment. You'll need to find out from the contactor that sold installed your equipment. he can email carrier, and they will answer him.
    May 2009
    Cumming, GA
    Infinity control questions
    Ok Dkirik,
    The infinity has built in chip (forget the name) that will store the programming and settings for a long time. I'm not sure of an exact number as to how long but I believe it is a pretty long time (months).
    If you are that concerned about it, swap to an infinity wifi touch controller. With this stat you can check and change the temp from a computer or app. This will allow you to monitor/change temps from whatever location you're at. See the link below.
    http://www.carrier.com/homecomfort/e...-systxccitw01/
    May 2013
    Dkirkey28
    THANKS BRENT RIDLEY. AGAIN
    NOT THAT WORRIED. DIDN'T KNOW IF I SHOULD BE OR NOT. DO YOU KNOW IF ITS A
    E-SQUARED ROM ? KNEW ABOUT THE WIFI/app. WAS HOPING DIDN'T NEED TO DO THAT.
    THAT'S GOOD INFO. DON'T KNOW WHY CARRIER DON'T JUST SAY THAT. SINCE I CAN'T
    GET CARRIER. THE CHIP NUMBER WOULD BE GREAT. PROBABLY THAT IS TOP SECRET.
    THAT WHY A SIMPLE ANSWER LIKE YOU GAVE IS GOOD.
    IS THE SWAP FREE.?
