Results 1 to 11 of 11
    Furnace installed this weekend for a friend
    Lennox SLP98
    Lennox icomfort wifi thermostat
    Lennox cabinet and merv 16 filter
    Lennox bypass humidifier
    new electrical to panel
    new pvc (used to be 3")
    new return from transition down
    new transition to a coil on supply
    Jan 2011
    Nice to see someone use metal... Where is the coil? no ac?
    You're a good friend
    Jun 2010
    Danbury Ct 1/2 hour from NYC
    nice work, glad to see a proper return air size. Also love the sheetmetal work, I've never used ductboard even on swap outs with existing db we use metal and tie in to the db.
    May 2013
    looks nice, I don't get any residential work in at work anymore. only on the weekends.
    Beautiful, Philadelphia, the City of Brotherly Love!
    Nice sheet metal, but one thing I would have done differently; you should reverse the return reducer to allow the connection at the filter to promote better air flow across the filter. I try to lower the velocity around filters in order for them to load up more evenly. In some cases we install turning vanes in tight locations.
    Here is a picture of an install done in this way. The discoloration from water damage is only on the surface, the builder had the roof off during a flash storm. Lucky the equipment was not in place, the camera flash picked up lost of dust particles, but you can see the return fitting. We also like sheet metal, on most jobs we use little or no flex duct.
    On this job we removed a gas fired steam boiler replacing with a three story duct job and this furnace. I tried to sell a Merv 10 filter case to these folks but granite counter tops won out. The trunk duct on this one was 14x16 for 3 tons of cooling, the equivalent length was pretty high as I remember, friction was about .045.
    “You don't get paid for the hour. You get paid for the value you bring to the hour.” Jim Rohn
    Jun 2002
    nw ohio
    "In some cases we install turning vanes in tight locations." - AtticAce
    i knew i liked you! i had an old timer tell me many years ago that if i added one turning vane at the throat of the elbow, i could get a lot of the benefit of turning vanes without having to install the other vanes in the elbow. it works.
    compressors never die; they're always murdered!
    wisconsin
    Nice work!
    Aug 2008
    San Clemente, CA
    Nice job Cody. I like that you elevated appliance off the floor.
    May 2012
    Upper Michigan
    Yep turning veins, when I would do the trane clean effects I would always use them. Looks great nice job
    Jun 2013
    Dill City OK, 73641
    Quote Originally Posted by jimmyed View Post
    Got your back on the sheet metal was worried everybody on this site was ruined with duct board
