Results 14 to 26 of 29
Thread: Brazing
    Mar 2009
    Mid-Mo
    Quote Originally Posted by socotech View Post
    Do you think they nitro purged while making this monstrosity?
    If they did, they needed a big cylinder or they would have ran out.
    Nov 2007
    Mississippi
    Ha ha yea!
    Jul 2012
    Western KY
    What I find impressive is that it appears they were able to bridge the gap between the stubs but couldn't seem to fill the freaking joint. Haha.
    Nov 2012
    Charlotte, Michigan 48813
    Quote Originally Posted by KB Cool View Post
    Gawd damn! Buy that man a rose bud tip!
    His used ox-acetylene kit only came with the cutting torch when he bought it, so a rosebud won't fit.
    I'm wondering if that's silver braze or plumber's solder.
    On a serious note, those who silver braze with ox-acetylene, do you use brazing tips or rosebud heating tips?
    Phoenix,AZ
    Quote Originally Posted by taxman View Post
    I use a smith mini torch! THe Twin tip on small pipe 3/8, 1/2" ! The C tip on 7/8 to 1 1/8"! The little normal tip for 1/4". The rose bud for RV's and then i have a giant C tip for big pipe like on the big blue 20 ton danfoss below! Here's what the welds look like!
    Nov 2012
    Is that The Little Torch that's marketed to jewelers or something else?
    Looks like a #0 brazing tip on a full size torch set could do anything The Little Torch could do.
    Phoenix,AZ
    No, it's for HVAC. It's called Quickbraze! Uniweld makes one too! Basically it's just a small torch handle for tight spaces. And some cool tips to help you out in tight spots!
    Jun 2013
    jeddah, saudi arabia
    :-( We had some experience with Carrier distributor field service technicians, who soldered the leaking condenser coils of our 30gt130-210 water cooled chiller. Will upload the pictures tomorrow here. I hope its ok, even if Im a new member with only 2 posts.
    Northern California
    I would replace the valve as well.
    Dec 2000
    Flat Rock, NC
    I have never damaged a reversing valve from overheating, now I guess I know why. BTW this proves that with persistence anyone can do anything!!!!!
    May 2009
    Cumming, GA
    The bigger the blob......the better the job!
    Oct 2008
    Quote Originally Posted by Brent Ridley View Post
    HAH! Catchy phrase...
    Reminded me one I use when tying off the lines of a boat to a dock, I tell people "If you cannot tie a knot....wrap it allot!"
    Nov 2012
    The set I found has a regular brazing tip, one that looks like a rosebud, and two horseshoe or "C" tips that would heat both sides of a pipe at once. Those C tips are a good idea that I'd never seen or heard of before.
