Thread: Nortec
    Long Island NY
    Question Nortec
    Does any one know the approx. electrode dept from the top of steam generator canisters and also the bdept of the high water sensor? Just a feild average. Thanks for the input!
    Impossible to tell. The level of water may be only 1" on a new tank depending on water hardness, or dissolved minerals allowing current to pass through the water. As the electrodes become fouled the level increases untill either the current becomes too low to heat the water or arcing in the tank occurs and the electrodes are completely fouled. the tank will over fill initally and then slowly dump and refill untill thei initial operationg level is found by the current sensor. I usually mark the tank on start-up and every oportunity there-after, I also check and log amp draw on each electrode, Nortec states that average operating life of the steam generator tank is 500-1500 hours depending water quality. This is energized hours, not installed hours.
    Charm City--the city that bleeds
    Quote Originally Posted by IN2AIR View Post
    their website is humidity.com the canister HW sensor is right near the top, like 1-1.5 inches from the top.
    not sure what you're asking, because mineral content will make or break any number we give you.
    have you ever seen what happens after the water main is opened on the street right out in front of the site?
    it's like a lightning display, even on new canisters.
    It's great to be alive and pumping oxygen!
