Thread: RLA to Tons
    Sep 2003
    RLA to Tons
    I don't think there is an equation for this, but is there a rule of thumb that converts RLA to tons?
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by bks2000 View Post
    you must be more specific on your questioning!
    generally speaking...no. the only time that you can accurately use RLA is under design conditions, which you rarely have...RLA stands for Rated Load Amps. if you are operating at the rating conditions then yes you can.
    Dec 2001
    Southern Tier, NY
    no
    SW FL
    Smile
    IF you have the Rated Load Amps, don't you also have the equipment model number?
    Designer Dan
