Results 1 to 13 of 15
Thread: Liebert
    Oct 2005
    Ohio
    Liebert
    M\N-MMD18E-PHEOP,S\N-992000106057
    today was the first time ever having to work on one ,the humidifier is not working and it's going into alarm,water fill valve works and goes through the cannister & out the drain,cannister was not hot,removed wire from fill valve and water shuts off,the book for the unit was not there so i'm not really sure what is wrong,thanks for any suggestions
    FL
    What was your alarm display on your operating controller? Your cannister may be max usage, did the contactor pull in for the electrodes? If you filled it and it drained w/o the contactor pulling in can has reached max.Go to lieb ert.com for IOM's.
    crossville
    Thumbs up two things
    depending on the style,
    some are true electrolisis steam generated, meaning they pass current thru the water, and if the water is CLEAN, meaning there isnt enough conductivity it wont steam, this usually occurs after and dump and fill cycle, I have had to add salt to the water to get one to start steaming, second if the heat element rods have depeleted then its time to replace the steam generator canistor.
    If you cant cool it
    HEAT THE Hello out of it
    Oct 2005
    Ohio
    the alarm said humidifier problem,setpoint is 30%,low humidity setpoint is 15%,the controller stated 17% room humidity and it was in the humidify mode but the cannister was cold
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by rix870 View Post
    holy bajibers that humidity setting is way to low (if there are computers present)
    newton,mass.
    Check the run/drain switch. The canister will not be hot if water is not staying in it.
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
    limit switch under the pan
    oops wrong model
    is there a float switch
    yes
    Feb 2007
    N.Y.C.
    Posting the Model number makes it possible to help. You have a 1 1/2 ton MiniMate With a steam generator Humidifier.
    Here is your link to the manual... Section 6.3.1 deals with the humidifier...
    Good luck
    http://www.liebert.com/assets/produc...t/sl_10530.pdf
    Wisconsin
    If the fill valve is open but the cylinder dosen't fill, the drain valve probably has crap in it. Clean the drain valve.
    crossville
    Thumbs up like i said
    Quote Originally Posted by esornivram View Post
    read 6.3.2 add small amount of salt to water and see if it goes to steaming
    if it does then have the water checked for the incoming conductivity levels
    some city water is so clean it wont steam, the conducitivy level should be above 200
    I added an swimming pool chlorinator to one once so it would keep working for an extended time frame, the city water was below 60 and wouldnt pass the current of the steam generator
    If you cant cool it
