Thread: B-Vent size
    Oct 2005
    MN
    B-Vent size
    I currently have an 8" B-Vent flue with about 30' of heigth. It is serving 2 nat. venting gas furnaces (160,000 and 108,000 btu) and a 75,000 btu nat venting gas water heater. If I have the 160,000 btu furnace changed out and vented with PVC will the flue have to be lined to a smaller size, or can it remain at 8" while only serving the remaining 183,000 btu max.
    Mar 2001
    Go with what your contractor says - he/they will have to deal with the AHJ (authority having jurisdiction)
    Kansas City
    As long as both the furnace & WH are natural draft hoods 8" is still ok.
    Oct 2005
    MN
    I looked at a couple B-Vent sizing charts and in both charts there was only a MAX btu for natural drafted, no minimum listed. Fan drafted has both a min. and max. SO am I to assume there is no btu minimum for natural drafted?
    Jan 2006
    Powell River, BC, Canada
    Quote Originally Posted by frankt View Post
    My tables show 2 spillage succeptable (nat draft) appliances with 183,000 btu input and 30' common vent height and double wall (b-vent) vent connectors needs a minimum of a 6" b-vent.
    In the general venting requirments, it states "When the table permits more than one diameter of pipe to be used for a vent or vent connector, the smallest permitted diameter shall be preferred."
    I would take that to mean you need a liner. I would assume too large of a vent would cause condensation and backdrafting issues. Your local codes and inspectors may be different though, so check with the authority having jurisdiction in your area.
    YMMV
    Where are you? Are you done yet? I got ONE more call for you.....
