Diffuser Position Fault in Chiller 19XR7272
Hi Guys,
Chiller is frequently tripping due to diffuser position fault while running.
When I reset the Fault & switch on Chiller starts running.
After sometime again the chiller Trips due to same diffuser position fault
can anyone explain me the solution to solve this problem.
How old is the chiller ? Are you over seas somewhere?
 Originally Posted by muruganbala.84
Hi Guys,
First thing to do is to calibrate the diffuser ring drive motor, if that doesn't do the trick then the potentiometer usually has to be replaced and recalibrated. Good luck.
...Ron
Roof Rat
Its a brand New Chiller. I am from chennai,India
Thank you. I will Try this & keep you posted
Then you need to get the people who installed it to come out and make the issue go away.
...Ron
Roof Rat
Call Carrier. If you mess this up, you will regret it.
- You may not post replies
- You may not edit your posts
Forum Rules
