Results 1 to 7 of 7
    May 2013
    Unhappy Diffuser Position Fault in Chiller 19XR7272
    Hi Guys,
    Chiller is frequently tripping due to diffuser position fault while running.
    When I reset the Fault & switch on Chiller starts running.
    After sometime again the chiller Trips due to same diffuser position fault
    can anyone explain me the solution to solve this problem.
    East of big city prices.
    How old is the chiller ? Are you over seas somewhere?
    May 2013
    Its a brand New Chiller. I am from chennai,India
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by muruganbala.84 View Post
    Then you need to get the people who installed it to come out and make the issue go away.
    ...Ron
    Roof Rat
    Jul 2003
    Orange County N.Y.
    Hi Guys,
    First thing to do is to calibrate the diffuser ring drive motor, if that doesn't do the trick then the potentiometer usually has to be replaced and recalibrated. Good luck.
    ...Ron
    Roof Rat
    May 2013
    Thank you. I will Try this & keep you posted
    Oct 2011
    La.
    Call Carrier. If you mess this up, you will regret it.
