Results 14 to 26 of 39
    ohio
    I don't know what tonnage it was doing but it was doing 10.2
    May 2013
    Quote Originally Posted by michael26 View Post
    gpm x delta t /24= tons. if your gpm was verified at 450 while doing 10.2deg your looking at 191t fully loaded with a 200t chiller. given you have 35% glycol your doing very good.
    Jun 2013
    Quote Originally Posted by traneguy123 View Post
    I wouldnt be too alarmed at your approach with 35%. i have several rtac's running the same approach with the same concentration, all is fine. just double check your design gpm to your actual gpm. your one issue of tripping you corrected by lowering sat temp trip point, that should have been done at start up. running 250 gpm originally seems quite low, unless the system is designed for low flow. what tonnage was the chiller putting out fully loaded?
    I have RTAC250 running with the approach so high +22 and up evap refrig temp 39.8 and lowering, refrig liquid level static on 0.3 no up no down, trane tech said that the sensor must be changed in order to open and close how has to be, any idea??
    Thank you in advance
    The Hot South
    Quote Originally Posted by ncctech View Post
    You should be starting your own thread instead of hijacking someone else's.
    Jun 2013
    Cond refrig Pressure 239.3 psia
    Sat cond refrig temp 138 F
    Evap refrig pressure 50.3 psia
    Sat evpa Refrig temp 39.8
    Evap Approach temp 21.2
    Refrig liquid level 0.3 (no up no down, static)
    In some point the unit stop by evap wtr flow (high approach temp)
  6. Likes Felipe.rapachi liked this post
  7. #19
    Jun 2013
    Quote Originally Posted by R123 View Post
    Ohh
    since we are talking about the same, i believe that was a good sample it is no my idea hack anybody just share the same situation
  8. #20
    May 2013
    whats your ambient temp? your sat cond seems a little high. water or glycol? % glycol? compare your actual gpm to design gpm. check sensors for accuracy.
  9. #21
    The Hot South
    I would take a close look at your leaving water temp sensor and make sure it isn't reading high.
  10. #22
    Jun 2013
    The ambient temp is about 80 F now, it is water not glycol, The liquid level sensor is static no up or down (+0.3)
  11. #23
    Jun 2013
    I set the unit to 49 F and the water is leaving about 59-60 F, may drop 5 to 6 degrees in 1/2 hr until the unit stop with the log evap wtr flow (high approach temp) about 35-36 F
  12. #24
    The Hot South
    Okay......but that doesn't mean you checked the accuracy of the leaving water temp sensor......
  13. #25
    The Hot South
    Also, what's the EXV position running at full load? Whats your discharge superheat at full load? What happens to the liquid level when you pump it down? Which sensor did the Trane tech say needs to be replaced? Why are you doubting your Trane tech?
  14. #26
    May 2013
    sounds like you have a couple problems. your saturated condenser temp is too high for 80 degree ambient. all your fans working? coils clean? bet your coils are dirty. need to check gpm through evap, quite possible a flow issue, maybe fouled tubes. is it a closed loop? any inhibitors or treatment in water? are your pressures and temps the same on both circuits? level sensor on both circuits steady? do a pumpdown on chiller and checked operation of level sensors, quick and easy to do.
